PT LE 9.01 Crashes with Mac OS X 10.6.6
I still have an issue where PT crashes a few seconds into opening a session. It doesn't seem to matter that I am in playback or doing nothing - PT still crashes out and I have to reboot to open it again. This is for lots of different sessions not just one. Also had DAE error and critical low memory errors before the crash - even though I have 8GB of memory... Things tried already - none of which works...
Rgds and thanks in advance. Gary Current setup: PT LE 9.01 Mac OS X 10.6.6 Mac Mini (top spec) Firewire Rack 003 2 x Firewire 1TB External HDD |
Re: PT LE 9.01 Crashes with Mac OS X 10.6.6
http://duc.avid.com/showthread.php?p...58#post1749358
Thats the word on the street now apparently.
Mac Pro, Snow PT 10HD,Sequoia, Reaper W7/64, PT 9HD,Sequoia, Reaper 192 HD, HD-N, 002C BLA, BLA AGB,Autuer,Lucid, MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Just to confirm - tried the following combinations...
Rgds, Gary |
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
Did you install the latest 003 drivers BEFORE installing Protools?
Please include the thread number in the subject of your email. |
I don't see what version you were upgrading from. Do you have any incompatible plug-ins?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Yes I did - however, I understand the latest 9.01 patch on the Avid website includes this fix anyway now?
Rgds, Gary |
Rgds, Gary |
Thought I'd try creating a new blank session with no plug-ins.
Imported an mp3 track and played it. Weirdly, I only got sound via the Aux In on the Rack 003!! Has anybody had that before? ie the output from the Mac rather than from the Rack 003?!? Very strange! Then it crashes after 10 secs.... Rgds, Gary |
PT 8.1 crashes | TAFE | Pro Tools TDM Systems (Win) | 4 | 11-08-2009 07:59 AM |
7.4 crashes | manbeargun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-15-2008 01:13 PM |
G5 crashes | CKoszuta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-19-2004 10:08 PM |
m box crashes | johnny5isalive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-06-2004 09:51 AM |
G4/733 & MTP USB Crashes | SOR | Pro Tools TDM Systems (Mac) | 2 | 10-04-2001 06:56 AM |
