Old 01-29-2014, 10:08 AM
silvermoonbeam silvermoonbeam is offline
Default Accidentally deleted "Small Room" setting DVerb
I thought I was deleting a custom setting for the "Small Hall" in the DVerb plugin, but instead must have deleted the default "Small Hall" preset as it no longer appears in the drop down list.
I have a clone of my drive and thought I could perhaps find the file that contains the default settings for "Small Hall" and restore it, but I don't know where these might be located. Does anyone know where these files are? I've found the DVerb plugin and opened the package, but didn't see any of the settings files.
MacBook Pro Max, Apple M1 Max, 64 GB RAM, Pro Tools 2021.12; Sibelius 2021.12
Old 01-30-2014, 05:16 AM
Stizz Stizz is offline
Default Re: Accidentally deleted "Small Room" setting DVerb
Documents/Pro Tools/Plug-in Settings/Dverb
Peace
Old 01-30-2014, 05:57 AM
Thanks for your response.
My plug-in settings were actually in Macintosh HD/Library/Application Support/Digidesign/Plug-In Setting/D-Verb, so I did finally find them. But the same location on my clone has the exact same files in it (to my surprise, as I have not cloned my drive since I thought I deleted this setting) and there's no file named "Small Room.txf", which is what I thought I had deleted. Maybe I didn't delete anything. It all happened so fast… but I was sure I had seen a listing for "Small Room" in the D-Verb preset menu.
I don't have a Pro Tools folder in Documents.
I have an offsite clone that I'll look at when I get to my office later today.
Old 01-30-2014, 08:53 AM
I have an installation of ProTools on my office computer—exact same version and OS—and I found the Small Room.txf file and copied it to my MBP. I won't get to start up PT for another day or two, but am hoping the preset will appear.
Just thought I'd post this in case anyone's been wondering what the solution was for me.
Thanks.
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! italianguitar Eleven Rack 15 03-20-2012 01:57 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
setting levels "naturally" vs. what "the books" say Felix Tips & Tricks 8 12-19-2001 05:23 PM
