Volume data corruption
I'm having problems with a PT file where certain tracks volume automation gets corrupted. After working on the file I save and come back to the session later. The affected tracks volume automation has shifted in time to the right beyond the boundary of the end of the tune, making the automation useless.
I've been able to correct this by trashing the databases on the disk containing the file prior to launching the file. However, the problem keeps recurring and now after trashing databases, repairing disk permissions, and following all the troubleshooting tips (other than uninstalling and reinstalling PT) the volume graph fails to move back to its proper location. My mix is sunk! Does anyone have an explanation for this? PT 7.1cs10 OS 10.4.6 PT HD3 Accel G5 2.0 dual (2nd gen) w/ 2.5 GB RAM (4) ext. Firewire 800 120GB drives Command 8 Digi 192 i/o Thanks for your responses in advance! |
Re: Volume data corruption
This is probably not it, but is there any possibility that some controller in your system is generating additional, unintended volume control data? Sometimes, controller #7 is assigned to multiple controls on MIDI controllers (like a foot pedal, and a slider). If you happen to have a slightly flaky pot on one of these controllers, it could be toggling back and forth between two values, and overwriting intended data.
Lee Blaske |
Lee, thanks for your response! No... I have no MIDI controllers generating #7... the volume data is not being overwritten but moved forward in the timeline way past the end of the song into the netherlands... it only happens on certain tracks... one track is an instrument track with Xpand VI...
Peace, Brandon
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Bump
bump redux
bump... is anyone home?
MIDI data corruption | Tim Wheeler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-04-2008 10:59 AM |
MIDI data corruption | Tim Wheeler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-04-2008 07:43 AM |
Data Corruption in HD7.1 Sessions | David Topple | Pro Tools TDM Systems (Mac) | 2 | 06-15-2007 09:27 AM |
digi tweak may cause data corruption | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 06-09-2004 06:36 AM |
Converting MIDI volume data to automation data? | Duff Studios | Pro Tools TDM Systems (Mac) | 2 | 12-17-2002 09:39 AM |
