Old 01-21-2013, 12:55 AM
dcmbeats dcmbeats is offline
Default ProTools 10 HD natively with AccelCore Card?
Hi Guys,
switching back from Nuendo to ProTools, I'm a little confused about all the "new" product names 10, 10HD, HDX, 10 native etc.
My question is: Is it possible to get a ProTools 10 HD working natively with an "old" AccelCore PCIe Card and a Avid HD I/O Interface?
MacPro 4.1
2xQuad-Core Xeon 2,66GHz
26GB Ram
Mac OSX 10.6.8
PT 10 HD 10.3.2
1x Accel Core Card
1x AVID HD/IO
Thanks in advance!
Old 01-21-2013, 02:42 AM
Jack Ruston UK Jack Ruston UK is offline
Default Re: ProTools 10 HD natively with AccelCore Card?
It looks a bit like this:
Pro Tools (v10): Runs natively with your choice of interface. Basic version. RTAS or AAX Native plug ins
Pro Tools HD Native: Runs the processing and mixer natively on the host, but has an HD Native card required to handle the IO. Connects to Avid interfaces (or any third party that are compatible with the digi connection) and has full HD functionality. RTAS or AAX Native plug ins only.
Pro Tools TDM (HD and HD Accel cards): Runs TDM plug ins and the mixer on the card. RTAS plug ins can also be used. Connects to Avid interfaces (or any third party that are compatible with the digi connection)
Pro Tools HDX: Runs TDM or AAX plug ins and the mixer on the card. RTAS or AAX native can also be used. Connects to Avid interfaces (or any third party that are compatible with the digi connection)
If you connect your HD Accel core card you will be running a TDM mixer. You can use RTAS plug ins for native processing. But as with all versions of the TDM mixer (TDM and HDX) there are certain inefficiencies when you switch to and from the mixer and the host. There is more latency than you would have running an RTAS plug in on a native mixer, and thus more processing required on the card to process the delays incurred.
J
Old 01-21-2013, 04:28 AM
Drew Mazurek's Avatar
Originally Posted by dcmbeats View Post
Hi Guys,
Jack covered the details well above but the short answer is no. Only 3rd party software can access the interface as a core audio device with 8 channels of I/O.
www.drewmazurek.com
Old 01-21-2013, 09:17 AM
J
Correct me if I'm wrong but I thought an HDX system only ran AAX and RTAS?
Jack
QAPLA!
Old 01-21-2013, 09:36 AM
I assumed he meant AAX-DSP.
www.drewmazurek.com
Old 01-22-2013, 12:44 AM
thanks a lot.
So, to get more than 96 tracks I have two possibilities:
1. get a "native" card and run PTHD10 natively or
2. get a second accel card and run PT as a TDM-System
Old 03-26-2017, 07:53 AM
rantanplan rantanplan is offline
I know that this is a very old thread. But I think that finding my answer here could still help someone:
You can use your old HD audio converter (96, 192) connected to a HD TDM card (Core, Accel...) with a non-TDM engine.
The magic word is: Jack Audio. Jack Audio serves as a bridge between CoreAudio and Pro Tools.
Normally, running Pro Tools with a CoreAudio engine does not allow you to select the aggregated device "Digidesgn HW (TDM)".
With JackAudio running, you can choose in Pro Tools an engine for "JackRouter" aggregated device, which routes the audio I/O from Pro Tools to Digidesgn HW. Like that Pro Tools is tricked to use its legacy TDM hardware for I/O.
However, I could test it successfully only with 8 outputs routed to a 96 I/O.
When I try to also enable inputs from the 96, Jack Audio server fails to start. But I think this is only a question of configuration.
Hope that helps.
Old 03-26-2017, 09:34 AM
Barry Johns Barry Johns is offline
Hi Guys,
MacPro 4.1
26GB Ram
Mac OSX 10.6.8
PT 10 HD 10.3.2
1x Accel Core Card
1x AVID HD/IO
Thanks in advance!
The first thing you need to do is upgrade that computer you have to a 12 core! If you look at my signature line, you will see I did the exact same thing.
It's a piece a cake, and after the upgrade, it'll match the specs of the current Mac Pro that sells for six grand. PM me if you would like some help with this.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 03-26-2017, 10:11 AM
JFreak's Avatar
JFreak JFreak is offline
thanks a lot.
HD Native only has two DigiLink ports, which means 64 i/o max. PT with 3rd party interface means 32 i/o max. To get 96 tracks you need either TDM (old world) or HDX (new world) system.
Janne
Old 03-26-2017, 10:50 AM
Hope that helps.
I wanted to offer a solution for the initial question: Is it possible to get a ProTools 10 HD working natively with an "old" AccelCore PCIe Card and a Avid HD I/O Interface?
Closest thing to HEAT possible Natively? DUCHUNTER macOS 27 06-16-2014 01:36 PM
Importing PT, Natively, Into Final Cut Pro dBHEAD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2011 07:47 PM
Pro Tools HD feature running Natively bortraws Pro Tools 9 17 03-28-2011 05:11 PM
PT HD 9 running natively ADC not working. mgoorevich Pro Tools 9 24 11-13-2010 03:03 PM
Does PTLE or MPOWERED support OMF???? natively? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-17-2007 10:47 PM
