Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-09-2012, 03:33 PM
groove guru groove guru is offline
Default Battery 3 mapped to EZDrummer grooves?
Has anyone mapped Battery 3 to play the grooves from EZ?
I'd like to be able to use some of the studio kits that I have for Battery 3, but when I insert Battery on the EZDrummer track only the kick and snare line up.
I'm pretty sure I can remap the Battery kits, but I just wanted to check if there is an easy way to do it.
Thanks,
Old 11-09-2012, 07:18 PM
nst7 nst7 is offline
Default Re: Battery 3 mapped to EZDrummer grooves?
It would be much easier to just put Battery on it's own Instrument track, and then drag and drop the EZ Drummer grooves to the Battery track. Basically you're just dragging the Midi info.
Old 11-10-2012, 06:12 AM
Yep, it is easier. But it's still going to be the same result.
I will likely create a custom kit in Battery to follow the EZX midi tracks.
Is Strike mapped to a V-Drum kit already? Farmer Dave Tips & Tricks 2 04-25-2009 11:11 AM
How Can I Add a Measures/clicks after tempo mapped???? Dizzi45Z Tips & Tricks 3 09-06-2008 11:59 PM
Waves R360 not mapped Pythagor ICON & C|24 3 02-04-2006 01:29 PM
? what EQs and Comps are curntly mapped to Craig F ICON & C|24 10 10-11-2005 11:50 AM
Looking for EQ+Compresor plug mapped to 8 encoders DonaldR ProControl, Control|24, Command|8 2 04-11-2005 06:52 PM
