Can\'t select audio between markers
I'm trying to follow the reference manual instructions for selecting audio between two markers.
I'm running PT LE 7.3.1 on XP. * Link Timeline and Link Edit selection are both selected (I've tried it without) * command keys are selected on (I've tried it without) * I've tried it with no grouping and all tracks grouped. The manual says that if I select a region of audio using the selection tool (this works fine) and then "Shift-click" on a marker, the selected audio should adjust to the position of the marker. Or this can be done by shift clicking on one marker then shift clicking on another marker. Shift clicking later in the audio does adjust the selection range, but I'm not able to select using the markers. The markers are absolute markers (diamonds). In all cases, the shift-click on the marker does nothing for me. I've tested it in several different sessions. I must have some option disabled or am missing something. Any assistance would be appreciated. Thx, Ben |
Re: Can\'t select audio between markers
The first marker that you're clicking on is not a shift-click. Click on the "start-time" marker THEN shift-click on the "end-time" marker. It will select everything in between. Or, let's say you had "Marker 1" and "Marker 2". On the numeric keypad, hit the following:
. 1 . (that will select at "marker 1") then do the following while holding down shift the entire time . 2 . There you go, it will select between markers 1 and 2.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
I appreciate the reply.
Unfortunately, I have tried what you mention. All of the methods that you mention are the same that the documentation mention. And I've had it working before in 6.7. I've tried creating new sessions, copying new session, I must have some setting in my PT set incorrectly. I'm completely at a loss. Any other suggestions would be much appreciated. Thx, Ben |
Place your I cursor on the track and click on a marker in the markers list and then hit ctrl-E to place a cut. Repeat for the desired end marker. Not the ideal answer maybe but it should work.
Beat Markers Appearing As Elastic Audio Markers | Fabdickson | Pro Tools 9 | 1 | 03-06-2012 05:03 PM |
Select area of audio in between markers | mediapimp | Pro Tools M-Powered (Mac) | 2 | 10-20-2009 09:10 AM |
How to select 2-4 sec. of audio while zoomed in | bradwarren | Pro Tools M-Powered (Mac) | 2 | 10-17-2007 11:12 PM |
Import Audio dialog , Can't select or play audio | Irl Sanders | Pro Tools TDM Systems (Mac) | 11 | 10-04-2006 02:02 PM |
no audio when no R select | sei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-18-2006 11:42 PM |
