Creative ASIO and PT10
I have PT10 and a Sound blaster x-fi titanium card that has an optical in and out...but I can't figure out how (or if I can) use that as an adat i/o. Unless they are already an option and I just don't know it. I've attached pictures of my "default" i/o, as well as a pic of my sound card's panel. Hopefully someone can help decipher what everything might be.
Obviously the inputs all correspond to the 1/8" stereo jacks (although I'm not sure they will actually work as inputs yet....) I'm just not sure what "mixed" means....digital and analog? The outputs make a little more sense...the first five again, correspond to the 1/8" jacks on my sound card...but I have No idea what the "FX" outputs could be... What I would really LIKE to do is use the optical in for some ADAT pres, and then use the 1/8" jacks to set up surround outputs. No, I don't have HD, but I've read that you can still technically process surround sound if you set your outputs correctly. Any ideas and help would be greatly appreciated. Thanks! Here's the in: http://imageshack.us/a/img560/8959/asioin.png Here's the out: http://imageshack.us/a/img211/2826/asioout.png Here's the panel for my sound card: http://imageshack.us/a/img543/6857/sbxan.jpg |
Re: Creative ASIO and PT10
Hi, Have you tried sending signal to all of your outputs? That's probably the best way to figure out exactly what's being sent to each output. You could send signal to one output pair at a time from Pro Tools - one of those could be going to the optical out.
Chris
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Only guessing here, but I would expect the optical out to be SPDIF only
Just found the data sheet....it's SPDIF....
Well...that was deflating....nevermind. Thanks guys. |
Possible to run HD Core 1 ASIO w/o installing PT10 ? | dan98 | Windows | 2 | 05-30-2013 02:23 AM |
Creative ASIO Help no sound | Zece | Windows | 0 | 02-06-2013 01:49 AM |
ASIO Driver Zoom H4n not working w PT10 | Kinnerfelt | Windows | 2 | 07-17-2012 09:59 AM |
Creative ASIO has taken over | sabayachi | Windows | 3 | 07-10-2012 11:08 AM |
Need PT10 help on Creative Collection | albee1952 | Windows | 10 | 04-20-2012 10:55 PM |
