Loop playback not working?
I have loop playback and loop record active. I highlight the section I want looped the same way I did with the 001, but the track keeps playing straight past the end of the section. Anybody have any clues?
Re: Loop playback not working?
Setups - preferences - OPeration - Timeline Insertion Follows Playback must be toggled on.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I think the loop also has to be a certain length in order to loop play,I forget the length.Rail had that number lately in a post.
DJ
6969 |
Its small - in the order of 500msec
Turn off any post roll (open the Transport Window to see if you have it enabled). Make sure your edit and timeline are linked (Shift+/).
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD •••••••••••••••••••••••••••• |
It's still here. But it seems you can no longer select within a region and get the playback that you want. Simply go to Options>Dynamic Transport and enable it. A timeline then appears at the top of your edit page in your chosen view (bars/beats, min/sec etc.) Make your selection in this time line. Of course make sure "loop playback" is enable as well. Shift+Command+L or Option+click the play button. Hope this helps
Loop Playback Not Working | Nathan W. | Pro Tools TDM Systems (Mac) | 15 | 08-12-2021 10:49 AM |
Loop playback not working since my 9.0.3 update | notrude55 | macOS | 9 | 02-24-2012 09:40 PM |
Loop Record and Loop Playback will not engage? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2008 06:03 PM |
About loop playback | stevegalante | Tips & Tricks | 4 | 09-22-2000 12:57 AM |
