Unable to import audio from .mov file
Hi there,
I've upgraded to Mac OS Catalina 10.15.7 and PT 2020.12. When trying to import an audio track from a QT movie or Mp4, the audio import does not start and the system locks up (spinning beach ball) when I hit the cancel button. Anyone else seeing this? Thanks, Roger 2013 Mac Pro, Catalina , 3Ghz, 8 core, 32gRam PT 2020.12 Ultimate, Apogee Symphony I/OMk2, HD Sync, Apollo8p, Sonnets XMac ProServer |
Re: Unable to import audio from .mov file
you can always open the MOV in Quicktime and Save As Audio...
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
I've Mac OS Catalina 10.15.7 and PT 2020.11 on my MBP and it imports audio from an mp4 without any probs. I think this should work just as well in 2020.12, so I'd try a clean session, a few different mov files and also trashing prefs.
[QUOTE=climber;2589520]you can always open the MOV in Quicktime and Save As Audio...
Thanks for the workaround C. That's working. I've tested import of various audio file formats and all are working well. I completed all the Mac OS optimizations, trashed pref's and reinstalled PT. Still cannot extract the audio from a QT or mp4 video file. The allocation for the audio track appears, then I select the destination folder, the "process window appears and nothing happens. Hitting cancel causes the aplication to crash..the mac spinning beach ball. I'll keep trying an report back if I find the culprit. Thanks again for the help. Roger 2013 Mac Pro, Catalina 10.15.7 , 3Ghz, 8 core, 32gRam PT 2020.12 Ultimate, Apogee Symphony I/OMk2, HD Sync, Apollo8p, Sonnets XMac ProServer |
I don't have the lock or crashing issue, however, I get the occasional grayed-out checkbox for "Import audio from file" during Video Import when I select a video file.
I looked up the file format (video and audio) of those video files (Get info) but cannot make out any pattern. These are all different file types (.mov, .m4v, .mp4) with different embedded audio formats (PCM, AAC)
Edgar Rothermich Author of "Pro Tools 2020 - How it Works" from the Graphically Enhanced Manuals (GEM) series http://DingDingMusic.com/ YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/ |
Yes we see it too from time to time.
My workaround is extracting the audio with Compressor, then importing and lining it up with the video. Good luck.
Ciao Gio |
unable to import MP3 audio in PT 12.6 | banjo71 | Pro Tools 12 | 2 | 11-06-2016 08:24 PM |
Unable to import audio... | OutbackStudios | Pro Tools 11 | 2 | 07-18-2015 05:03 AM |
Unable to import mp3 audio in Pro Tools LE 8.0.4 | d_sellers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-10-2010 04:53 PM |
Unable to import CD audio tracks | BoomTap | Pro Tools M-Powered (Win) | 0 | 04-02-2010 10:50 PM |
Import Audio to Session Causes DAE -1103, Unable to re-aquire Audio | musictycoon | Pro Tools TDM Systems (Mac) | 5 | 09-25-2008 12:31 PM |
