Old 11-10-2023, 11:10 AM
Rooxii Rooxii is offline
Default Different colour for muted Midi notes.
As in the title.
It's a stunningly basic requirement.
Tell me there is an option I haven't l seen.
The lack thereof would be tantamount to painting all the stripes of a zebra-crossing either black or white. ,-)
Rerum cognoscere causas.
Old 11-10-2023, 12:20 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: Different colour for muted Midi notes.
They... change color... to grey. Which is consistent with the same behavior when you mute Clips (audio or MIDI) in PT. Or in a lot of kinds different apps in general (see "greyed out" as a commonly accepted term) I don't know why they'd change that.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 11-10-2023, 12:43 PM
Greyed-out...? Thanks for that, Sherlock. ,-)
Sure, why would you want to change it. Makes sense – make muted notes the same colour as active ones. That'll help.
While we're here, and as you're clearly more enlightened than I am, help me find the muted noted in the attached image. I'm sure you'll find it easy. (They're the grey rectangular blobs – see "midi note" as a commonly accepted term).
Old 11-10-2023, 01:13 PM
AH..... I see. I haven't seen a grey-colored MIDI track in ages, but I do remember that. I suggest just changing the Track color to anything other than grey. Then also make sure you have Default Clip Color Coding set to "Track Color" (or whatever makes sense to you) in the PT Settings.
Or you can click one of the 2 buttons I've circled in the upper-left of the attached image. Those will let you toggle the Note colors. (I forget the exact way they work. It's in the manual).
But the muted notes will be grey, so I suggest using any color other than grey. The two Bb notes in my example are muted, for instance.
File Type: jpg Screenshot 2023-11-10 at 1.07.31 PM.jpg (35.1 KB, 0 views)
Kerry Smith
Old 11-10-2023, 02:08 PM
Originally Posted by massivekerry View Post
...Default Clip Color Coding set to "Track Color"...
Ah! How did I miss that! Solved.
Thank you kindly, me hearty.
Truly you have earned your swig of rum this night. ,-)
MIDI editing in PT... Can I delete all muted notes? Jon_Atkinson Pro Tools 10 06-06-2023 02:17 AM
Midi notes randomly muted during recording stevegalante Pro Tools 12 4 11-17-2017 09:11 AM
midi notes are being truncated/muted at at random times kemosabi73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-29-2010 11:29 AM
Invisible MIDI notes - bad colour coding? Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-08-2005 08:14 AM
Changing the colour of muted parts djan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-15-2002 04:41 AM
