Sibelius 6.1 is not showing in instruments
Sibelius 6.1 is not showing in instruments so I cannot rewire pro tools M powered 8.03 with Sibelius 6.1. Does anyone know the solution to this?
On reading the documentation it may be because I haven't got the DigiRack rewire plugin, if this is the reason then how do I obtain this plugin?
Dual core Quad Q9550, 4 GB RAM Windows 7 Ultimate 64 bit, Audiophile 192 |
Re: Sibelius 6.1 is not showing in instruments
seems as if not many people are using Sibelius with protools! For the record the solution is to press the repair button in the Sibelius playback engine. This will force the rewire mode and Sibelius will appear in the instruments list in protools.
What if the 'repair' button is greyed out? I've installed RW from the Sib CD and although it says successful I can't find the plug anywhere and it still doesn't show up in PT (HD Native, 10.2; Sib 7.1.2)
Thanks in advance if you have a clue as to where go from here.... |
Virtual Instruments Not showing up in PT10 | undermyumbrella | Virtual Instruments | 4 | 12-30-2013 04:25 PM |
Instruments not showing in Inserts | robert1 | macOS | 0 | 02-15-2013 08:11 PM |
Sibelius not showing up in Pro Tools | Matt Wendzina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-14-2010 06:01 AM |
Sibelius 6 not showing in instruments | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-16-2010 05:33 PM |
Reason, Live not showing up under Instruments | alexbutterfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-09-2006 09:48 PM |
