Need help with DT
Hello Folks,
I just got DigiTranslator hoping in wouild ease the burden of importing omf from an Avid using media comopser 7.x Heres my confusion: I have a CD of the avid session which contains 87 SD2 sound files and an Omf of the session document (its a one hour tv show). DT will translate the info from the session document in the file name window..but when I hit "Save" I get the "Where is (file name....)" dialogue prompting me select a folder. I select the folder with the 87 sound files and the prompt keeps repeating...If I hit "Skip all" and continue is does translate a Protools session but there is only one corrupt sould file in the regions list. Is the Avid Editor exporting correctly or am I overlooking something very obvious... Thank you in advance...Roger Stauss. |
Re: Need help with DT
The "Where is" dialog isn't asking you to select a folder. It's asking you to select the actual file.
Paul Greyson Digidesign Engineering |
