Sync problems digitizing picture
Set up
Aurora Igniter capture card, Pt Mix3 Digi 13 slot Expansion chassis Protools 5.1.1 USD and Aardsync OS 9.1 on a Mac G4 500 I have the following problem. When importing a movie, digitized through the Igniter card, into protools, the picture's burnt timecode on the movie screen, goes off with the Protools timeline after around 6 minutes. I've digitized the picture using Final Cut Pro, which goes well. No drop outs or anything. And I believe all my settings are correct. However, there's no timecode being send into the Mac when digitizing. I'm relatively new to this procedure, but it's driving me insane and I can't find a solution. Frames rates are set to 29.97 ND in both FCP and Protools. I'm I forgetting something? Anyone have any suggestions, or settings I should look at? |
Re: Sync problems digitizing picture
quote: BN: Check your timebase setting in FCP and see if it is 29.97 as well. Also, are you clicking the pulldown button in PT or not? If so, then picture is being pulled down again (double pd is a no no of course). You might mention which is getting progressively longer PT counter or burn-in (points to who is running slower). Good luck, -Polaris [ September 10, 2001: Message edited by: Polaris ]
Polaris |
Thanks Polaris for the response,
The picture is running faster than protools. Pull down is not checked. I'll try the setting in FCP, but I think I set everything in FCP to be 29.97 ND. Somebody from Aurora told me that this is a common issue and that the capture disk might be to fast!?!? Apparently there is a setting for that, I'll have to check. |
Could it just be that something in the chain isn't being referenced to video -- like either Pro Tools or Final Cut or the video deck from which your footage was originally taken?
iMac 2.66 GHz (8.1) 320 4 GB RAM OS 10.6.5 500 GB Western Digital My Book Studio FW 800 Pro Tools 9.0 002 |
Digitizing Vinyl - Distortion Problems | adamchicago | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2008 10:18 AM |
Mojo and 3/4" Digitizing Problems | cpunthank | Post - Surround - Video | 6 | 05-10-2007 04:50 AM |
Bounce to QT - Picture out of sync! | rotidexm | Pro Tools TDM Systems (Mac) | 2 | 08-30-2006 11:57 PM |
TDIF/DA88 digitizing problems | Katherine | Pro Tools TDM Systems (Mac) | 2 | 09-06-2005 02:24 PM |
Sync - PT to picture...what are the facts | Jay | Tips & Tricks | 6 | 02-20-2000 03:48 PM |
