Unity Media composer Digitranslator ProtoolsAV
Hello,
We are using media composer 10.1.3, unity, digitranslator Cs03 and protools 5.1U. We have some video problems when we export video sequence from Mediacomposer (OMF2) to protools, using Digitranslator. In prootools the sound is correctly imported but some video footage are not the right one. The video cut(in and out point)are OK but the images are not the same as in the mediacomposer. There is no problem if we do a consolidate on the MediaComposer before exporting the OMF. We don't want to consolidate because it take's a lot of time. Is it a problem of MediaComposer, digitranslator or protools. Can i solve this problem? Thanks in advance. |
Re: Unity Media composer Digitranslator ProtoolsAV
the video through unity is extremely random. sometimes she works, sometimes she doesn't. i have a similar set-up as you with varied results. check my replys in the 'last location unknown' thread and see if anything helps and/or makes sense... best.
Matt Foglia, CAS |
quote: Is DigiTranslator producing any "Translation Notes" in the cases that you're seeing the wrong video?
Paul Greyson Digidesign Engineering |
Media Composer 11.8 OMF | Clash310 | Post - Surround - Video | 0 | 08-11-2003 03:51 PM |
1.0 and Media Composer 10.0 | EasternSky | Post - Surround - Video | 14 | 06-01-2001 05:44 AM |
Audio Exchange: ProToolsAV / Avid Film Composer? | Stephen Kearney | Post - Surround - Video | 5 | 03-19-2001 09:15 PM |
Media Composer/A.V. OMF | Rick Sanchez | Post - Surround - Video | 5 | 01-11-2000 12:19 AM |
Media Composer/A.V. OMF | Rick Sanchez | Post - Surround - Video | 0 | 11-23-1999 09:43 AM |
