MIDI Volume CC Automation won't read
On an Instrument Track, I have a CC volume fade at the end of a MIDI note, and Pro Tools 11.0.2 won't read the automation that is written.
The problem started when I changed virtual instruments and subsequently rerouted the MIDI. Since then, I cannot get PT to recognize the CC volume data. It will recognize other CC data that I programmed (CC#71 and CC#74) but just not MIDI volume. I tried creating a brand new Instrument Track, re-instantiating another instrument with the same settings, moving the old MIDI clip to the new track, and finally consolidating the new clip on the new track... and nothing. Replaying the performance and reprogramming the other automation is not an option. Any ideas?
iMac Pro 3.2 GHz 8-Core Intel Xeon W 32GB RAM OSX 10.15.5 Pro Tools 2020 |
Re: MIDI Volume CC Automation won't read
Is this CC7?
Which virtual instruments, and are they set up to respond to all incoming CC data?
Yes.
Thanks for your help. I'll try to trick the plug-in into reading the automation.
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
Volume automation question on midi tracks in PT8 | WestphalMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2009 11:30 PM |
Midi volume automation when there was none | smlworld | MIDI | 0 | 06-07-2007 06:03 AM |
MIDI Volume Automation | JaxMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-22-2006 09:04 AM |
Volume automation not being read... | TimNielsen | Pro Tools TDM Systems (Mac) | 1 | 04-25-2005 04:10 PM |
