Old 06-24-2021, 07:23 PM
LukeHoward LukeHoward is offline
Default Hybrid Engine thoughts
Very clever feature! Some comments/questions:
How do I make sense of Input and Output Channels in System Usage? If I have a single audio track with a single hardware insert, it shows as 2 output channels. But if I put a (native) insert before that, it shows 0 output channels. HW insert/native/HW insert: 2 output channels (same in DSP Mode, too). Just asking out of curiosity.
Also, I'm hearing a little glitch (short 750Hz sawtooth like burst) when deactivating a hardware insert whilst a track is playing.
Finally, feature request, not really related to Hybrid Engine: can we have bypass on hardware inserts please?
https://lukehoward.com/
Old 06-25-2021, 06:09 PM
Default Re: Hybrid Engine thoughts
Only other thing I've noticed since upgrading to 2021.6 with the Hybrid Engine is some -9093 errors, generally after changing session sample rate.
I can't reproduce them reliably, although it appears when changing session sample rate they are logged; what is intermittently reproducible is whether they show a dialog which prevents playback (until restarting Pro Tools).
The buffer size is generous and the session on which it is occurring only has two audio tracks.
Code:
1675.146031,00307,0e0c: Establish communication with sync peripheral, hardware type: Sync X, firmware type: Sync X, firmware version: 1.0.0.24, serial port:
1675.149966,00307,001b: CSync::UpdateUniversalSlaveDriver
1675.201545,eca0f,0e34: ERROR from CHostXDevice: err = -9093
1675.201708,00307,0b09: SLnk_UMEClock::ResetClock
1675.201714,00307,0b09: SLnk_MachineMgr::SendResetClock: inIsUME - true
Old 06-26-2021, 06:58 PM
Also seeing this spinning in logs when I get the -9093 error:
Code:
91265.411397,128003,0e34: ERROR from CHostXDevice: err = -9093
91265.423696,11462f,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
91265.474086,11462f,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
91265.512495,128003,0e34: ERROR from CHostXDevice: err = -9093
91265.524825,11462f,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
91265.575680,11462f,0b09: SLnk_UMEClock::UpdateRunningTime got a 0 running time!
Case 04196133.
The Hybrid Engine LDS Pro Tools HDX & HD Native Systems (Mac) 64 07-31-2021 09:17 AM
Will HDX hybrid engine affect VI performance? Dave S. Pro Tools 3 06-24-2021 12:04 PM
Hybrid engine effect on S6 basehead617 Avid S4/S6 8 06-08-2021 03:50 PM
What is the Hybrid Engine? loopzilla2 Pro Tools HDX & HD Native Systems (Mac) 31 04-22-2021 07:11 AM
upcoming Hybrid Engine HDX Option? DetroitT Pro Tools HDX & HD Native Systems (Mac) 16 03-01-2021 04:34 PM
