Old 12-30-2023, 12:42 PM
Daniel_H Daniel_H is offline
Default Copy and paste issue
I saw some other posts about this elsewhere. Basically, after a few copy/pastes, the shortcut stops working and I have to reboot Pro Tools to get it back again. Does anyone know why this is happening?
I am on version 2023.12.0 (Artist).
Thanks!
Old 12-30-2023, 12:55 PM
climber climber is offline
Default Re: Copy and paste issue
what computer & OS? not seen this...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 12-30-2023, 12:56 PM
skylar_battles skylar_battles is offline
Are you holding down the modifier key (not sure if you’re on Mac or PC) or just C and V? Are you sure it’s not keyboard command focus if that’s the case? Option Command 1 (Mac) and that should fix it hopefully!
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 12-30-2023, 03:36 PM
I'm running it on a Dell / Windows 11, 64-bit, i9.
Old 12-30-2023, 03:38 PM
On Windows just Ctrl C or V.
I haven't heard of the keyboard command focus before. I'll look into that.
Old 01-02-2024, 05:21 PM
Schottlandru Schottlandru is offline
On my Win sometimes modifier keys like Alt etc get stuck... Try hitting Ctrl a few times to get PT to realize they are still there :)
Hope it helps!
Old 01-10-2024, 04:43 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Sometimes I have to open and close Microsoft Mouse and Keyboard Centre to get my custom mouse settings to be recognised, but if you're just using vanilla windows cut and paste I'm not sure what the solution is.
A stuck key like Schottlandru says is a definite possibility. I replaced a keyboard last week for that very reason.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 01-11-2024, 09:33 AM
The Weed's Avatar
The Weed The Weed is offline
Best Windows mouse driver I've found is X-Mouse Button Control - and it's free.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-11-2024, 11:54 PM
TamiaLittle TamiaLittle is offline
Banned
Thanks, I will try it. I am new here and have some doubts, Can I ask it? Ever felt the pressure of potentially compromising your degree due to rushed assignments? This write my essay in Canada service https://canadianwritings.com/ is the lifeline you've been searching for. Their services are not just about completing assignments; they're about ensuring your expertise shines through. Affordable, reliable, and a true academic lifesaver.
Duplicate/Copy Paste Issue Roulette Records Pro Tools 12 8 04-19-2016 01:41 PM
Copy/Paste Issue Causing Audio to change pitch Drumbum7 macOS 2 06-03-2014 07:07 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
Copy and Paste issue in 6.4.1 Paletteman Pro Tools TDM Systems (Mac) 3 12-12-2008 11:48 AM
