Automation Follows Edit bug 2023.12
Hi All,
Finding a big bug in PT 2023.12 with Automation Follows Edit. If I copy/paste a clip with automation from one section to another with it in Blue (on) the automation follows the paste, but when it’s orange (off) it still pastes the automation. Can anyone else confirm this on their end too? Thanks! |
Re: Automation Follows Edit bug 2023.12
Hasn't this always been the case? It affects the data of the copy process, not the paste AFAIK.
No. Try this in 2023.9. Works as intended. This broke in .12
I only have 2023.12 installed so that's all I can test on.
When automation follows edit is enabled, and edit selection will automatically encompass all automation lanes even when they are not visible. But you are right that if you copy a selection with AFE enabled, and then turn it off and paste, it still pastes automation which doesn't quite make sense since the edit cursor doesn't extend into the automation lanes. Curious to hear from the developers regarding this. Thanks for bringing it to my attention.
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
It does affect the Copy not the paste. So if you copy with AFE On it will retain the automation in the clipboard even if you then turn AFE Off. Been that way as long as I can remember. It has be Off before you Copy.
~Will |
agree with smurfyou
It's part of the first step of copying.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Interesting! I've been using this program for about 15 years now and just learned something new. Thank you for clarifying that function everyone. Disregard this as a "Bug" then.
2023.9 - Edit Cursor Screen Artifacts When Selecting a Clip | audiogamble | Pro Tools | 29 | 11-16-2023 06:00 AM |
PT 2023.6 expand Edit pane->Spinning wheel | frenchman | Pro Tools | 0 | 06-28-2023 02:04 AM |
2023.6 -Getting into state where changing automation mode changes it for all channels | basehead617 | Pro Tools | 0 | 06-20-2023 10:03 PM |
Automation follows edit vs edit writes new automation | RyanC | macOS | 4 | 10-12-2012 05:05 PM |
