Old 01-26-2023, 02:27 PM
wdjudd wdjudd is offline
Default Why do Pro Tools sessions always open to far left channel position?
My signature has all of my system and Pro Tools versions.
Why do Pro Tools Sessions always Open to the beginning of the session?
When ever I open a Pro Tools session, it immediately moves to the most far left channel position, no matter if I saved the session in the far right region. Why does this happen and how can I stop it. Also, If I have a session open and the session Mix View is far right by the Master Channel, if I change to the Finder and then back to Pro Tools, the sessions jumps to the far left position again.
Put another way. If a Pro Tools Session is 5 minutes long, and when I stop mixing for the day my cursor was at 3 minutes and saved that way. The next time I open the Session, it always jumps to the beginning of the session.
Driving me crazy. Any ideas how to stop this action? Thanks.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD
Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB
Old 01-26-2023, 03:57 PM
take77 take77 is offline
Default Re: Why do Pro Tools sessions always open to far left channel position?
As regards the last issue, see if saving with "playback follows insertion" enabled helps.
Or doing just the opposite, make a selection and see if it remembers upon opening.
Maybe the other "follow" settings might be a factor too? Dynamic transport?
Not positive on that. Just some thoughts.
Someone who knows more about saved configurations might have the answer.
As far as the first issue, I haven't experienced this or just haven't noticed it . But do know frustrating things can happen.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 01-26-2023, 05:22 PM
Thanks . . . I'll give these a try. A similar thing also happens in Mix View. If I have scrolled right to say the Master fader, select the Master fader so the name is high lighted, save the session, close the session and then open the session, Mix View defaults to the most far left channel? It's crazy.
Old 01-26-2023, 09:27 PM
JFreak's Avatar
JFreak JFreak is offline
I find it interesting someone asked this. I have never questioned why my computer starts with cursor at 1,1 position (top left). Maybe there should be a way to save the window configuration on session level.
Janne
Old 01-26-2023, 09:46 PM
its2loud its2loud is offline
I suspect something on your system is inadvertently triggering the Return key which is causing the cursor to go to the head (far left) of the session.
Old 01-27-2023, 02:37 AM
Couldn't repro on my Windows setup.
The cursor maintains it's position regardless of the settings I mentioned and mix view opens with far right in view when I save it that way.
I should mention I'm currently using 2022.7.
Not sure what it could be on your end but hope you can figure it out.
Old 01-27-2023, 09:47 AM
The cursor maintains it's position regardless of the settings I mentioned and mix view opens with far right in view.
Thanks for trying to reproduce this issue on your Windows system. I am still looking for an answer for Mac. Thanks again.
Old 01-27-2023, 10:55 AM
I think take77 might have the solution. My sessions always open and play from exactly where they were saved(not at my rig right now so can't check that setting)
Old 01-28-2023, 03:08 AM
You're welcome fellow member.
Hi Dave,
Turns out none of the settings I mentioned had any effect on the cursor position and the sessions still opened as I left them.
Disregard all on that.
I was happy things saved as I left them but was hoping to discover something for the OP.
Old 01-28-2023, 08:06 AM
Are you using any control surfaces or Avid Control? I would try disconnecting *all* peripherals except wired keyboard and seeing if it changes - as is probably clear now, that's not normal behavior.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Eleven Rack monitor only audible in left channel in Pro Tools Spara Eleven Rack 1 02-07-2015 03:27 PM
Left channel click track bleeding into right channel lokimojo macOS 5 08-29-2014 11:44 PM
Runner Position Open arrowood101 Employment 2 09-09-2013 04:18 PM
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 08:42 AM
Pro Tools Audio Playback only in Left Channel Sean12345 General Discussion 3 10-12-2010 06:16 AM
