Copying, looping, or pasting Midi notes
I'm programming drums on a MIDI track and when I record a groove,
I want a fast way to select and copy two or so bars of the kick Drum ONLY notes (this step is that's easy) and drag them, loop, or copy and put them on the same track without messing up the high hat snare and tom parts on that track . Can someone recommend me a fast way of doing this? |
Re: Copying, looping, or pasting Midi notes
One thing you can do is have a midi track for each drum. It will make the kind of editing you are talking about easier in some ways.. Otherwise, you will be trying to select using a box and then copying and pasting. I'm not sure, but I don't think Loop, Duplicate, or Repeat will work with just selected notes...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Click the pitch at which the kick is located on the Reference Keyboard.
filosofem |
Then what?
MBox2Pro / LE 8.0.5 |
That's what I was looking for... quick and easy I'm new to Pro Tools 8... Coming off of Cubase and going through the learning curve. I know everything's possible if you just know the trick. Started using Pro Tools 8 for a week or so ... Love it so far ... Thanks again !!! |
pasting midi notes deletes others | Shatzer | Pro Tools M-Powered (Win) | 11 | 03-30-2014 01:22 PM |
Copy and Pasting MIDI Notes Issue | ianbee | Pro Tools 10 | 2 | 03-02-2013 10:54 PM |
copying midi notes? | thearnicasync | MIDI | 11 | 06-03-2007 04:34 AM |
Copying midi notes? | thearnicasync | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-22-2007 09:09 PM |
Looping and copying and pasting | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-17-2003 08:53 AM |
