WEIRD! Audio playing back at higher pitch - help
Hey, I had to totally reinstall protools because of a hard drive failure. now when i open sessions protools plays them back audio at too high a pitch. anyone have any idea how to fix this? its killin me!
jla |
Re: WEIRD! Audio playing back at higher pitch - help
Check your sample rate Joseph. Chances are you were recording at 44.1K and when you reinstalled PT it got switched to 48K. Or if you're using an outboard device to sync to, it's possible the outboard divice's sample rate clock got switched to a higher sample rate. In any case, my bet is it's the sample rate. Good luck.
sample rate is at 44.1 in the re-installed protools. this is really scaring me because all my old work, which is precious to me, won't play back properly.
my belief is that i've been using the same sample rate all along. help!
jla |
Are you clocking or attached to any external digital devices like a DAT player or reverb? Make sure your clock source is set to internal in your hardware setup / playback engine.
Recording playing back at different speed and pitch. | Ripley1046 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-27-2009 01:50 PM |
need help playing back audio at 36 fps & 40 fps | syncitupmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-13-2008 03:37 PM |
Loud hi pitch tone when playing back | Anibal | Pro Tools TDM Systems (Mac) | 3 | 07-15-2006 02:45 PM |
Weird noise when playing back vocal track with buffer size under 1000 | mixmasterc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-05-2002 08:15 AM |
Tracks Playing back at double speed/pitch | Louie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-14-2001 03:38 PM |
