Old 08-22-2003, 12:35 PM
Joseph Anderson Joseph Anderson is offline
Default I need help - problem w/ Ableton Live ASIO driver
Hey guys, I could really use some help. You may recall that I had a total hard drive failure on my main drive (fortunately data was backed up!)
Anyway, I had to replace the drive, reinstall PTLE etc., and in the course of this I had to reinstall Ableton Live.
I put the ASIO driver into the resources folder but Ableton Live will not "see" the driver when I try to choose ASIO in audio preferences. its as if the driver isn't there. The only option given is soundmanager. I'm trying to play the audio through the digi.
I read somewhere to make sure the asio driver is the actual driver, not an alias. I've tried to make sure that's the case by copying the driver directly from the PTLE CD (and later the download from digi's website) into the resources folder. no joy. the driver shows it consists of 365 k so i think its not an alias. I'm at a loss. Help!
jla
Using HDX and OMNI as core audio driver with Ableton Live Thunderbay Pro Tools HDX & HD Native Systems (Mac) 0 09-21-2012 05:52 AM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
ASIO for Digi 002 Rack problems in Ableton live? Adam Jenkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-15-2006 07:37 PM
ASIO Driver with Reason, Ableton, etc. moonpuppy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2005 05:07 PM
ableton live 4 + free asio driver neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-13-2004 01:38 AM
