Re: PT hangs on DAE Loaded
Don't know if this applies to you or not, but I also had the same issue.
Funny thing is this JUST started happening today, previously, PT loaded fine. I did notice overnight some updates to XP were automatically installed. I uninstalled Windows XP Hotfix KB932823-v3 and then PT loaded just fine. Just go into Add remove programs, check the box that says 'Show Updates' . Find Windows XP Hotfix KB932823-v3 and uninstall it. My machine is an AMD dual core, I suspect this has something to do with it, although it's hard say for sure... Joel Tipke |
I'm not sure if I should post a new topic, but I'm having this exact problem. Background: 002 running 7.4cs4 on xp home works fine. Bought a new laptop last week and installed this same setup. Installs fine, loads, runs plug-ins, goes through DAE then hits "DAE Loaded" and stops. Just sits. I've waited 10 minutes, and nothing.
Here is part of my sandra report: < Processor > Model: Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz Speed: 1.83GHz Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Mobile, Dual-Core Internal Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < System > System: TOSHIBA Satellite A300 Platform Compliance: Intel Centrino Duo Mobile Technology Mainboard: TOSHIBA Satellite A300 Bus(es): ISA PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes System BIOS: TOSHIBA V2.70 Total Memory: 1.99GB DDR2 < Chipset > Model: Toshiba Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed: 4x 166MHz (664MHz) Total Memory: 2GB DDR2 Shared Memory: 8MB Memory Bus Speed: 2x 332MHz (664MHz) < Video System > Adapter: Mobile Intel(R) 965 Express Chipset Family (PCI, PS 3.0, VS 3.0) < Physical Storage Devices > TOSHIBA MK2546GSX 250GB (SATA1:233GB (C:) (D:) HL-DT-ST DVDRAM GSA-T40N (ATAP:N/A (E:) TA4313Q HUZ044K (ATAPI, DVD+-R:N/A (F:) < Logical Storage Devices > TOSHIBA SYSTEM VOLUME: 1GB (NTFS) S3A6573D004 (C:): 219GB (NTFS) @ TOSHIBA MK2546GSX 250GB (SATA150, NCQ, 8MB Cache) Hard Disk (D:): 6GB (NTFS) @ TOSHIBA MK2546GSX 250GB (SATA150, NCQ, 8MB Cache) CD-ROM/DVD (E:): N/A @ HL-DT-ST DVDRAM GSA-T40N (ATAPI33, DVD+- RW, CD-RW, 2MB Cache) CD-ROM/DVD (F:): N/A @ TA4313Q HUZ044K (ATAPI, DVD+-R-DL, CD- R) < Peripherals > LPC Hub Controller 1: Toshiba ICH8M-E (ICH8 Family) LPC Interface Controller LPC Hub Controller 2: Toshiba 82801H (ICH8 Family) SMBus Controller Audio Device: Toshiba 82801H (ICH8 Family) HD Audio Controller Audio Codec: Conexant Systems ??? (5051) Serial Port(s): 1 USB Controller 1: Toshiba 82801H (ICH8 Family) USB UHCI #4 USB Controller 2: Toshiba 82801H (ICH8 Family) USB UHCI #5 USB Controller 3: Toshiba 82801H (ICH8 Family) USB2 EHCI #2 USB Controller 4: Toshiba 82801H (ICH8 Family) USB UHCI #1 USB Controller 5: Toshiba 82801H (ICH8 Family) USB UHCI #2 USB Controller 6: Toshiba 82801H (ICH8 Family) USB UHCI #3 USB Controller 7: Toshiba 82801H (ICH8 Family) USB2 EHCI #1 FireWire/1394 Controller 1: Toshiba Integrated OHCI IEEE 1394 Host Controller System SMBus Controller 1: Intel 801xx/63xx SMBus < Printers and Faxes > Printer: Send To Microsoft OneNote Driver (300x300, Colour) Printer: Microsoft XPS Document Writer (600x600, Colour) < Network Services > Network Adapter: Marvell Yukon 88E8040T PCI-E Fast Ethernet Controller Wireless Adapter 1: Intel(R) Wireless WiFi Link 4965AGN (802.11g (ERP), WEP n-bit, 54Mbps) < Power Management > Mains (AC) Line Status: On-Line Battery No 1: 42% < Operating System(s) > Windows System: Microsoft Windows Vista Home 6.00.6001 (Service Pack 1) Platform Compliance: x86 < Windows Experience Index > Current System: 3.5 <<< Processor Arithmetic >>> -------------------------------------------------------------------------------- < Benchmark Results > Dhrystone ALU: 15549MIPS Whetstone iSSE3: 11731MFLOPS Results Interpretation: Higher index values are better. < Windows Experience Index > Current Processor(s): 4.8 Results Interpretation: Higher index values are better. < Performance vs. Speed > Dhrystone ALU: 8.50MIPS/MHz Whetstone iSSE3: 6.41MFLOPS/MHz Results Interpretation: Higher index values are better. < Performance vs. Power > Processor(s) Power: 24.66W Dhrystone ALU: 630.54MIPS/W Whetstone iSSE3: 475.71MFLOPS/W Results Interpretation: Higher index values are better. < Performance Test Status > Run ID: Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz (2C, 1.83GHz, 2MB L2, 664MHz FSB) Platform Compliance: x86 NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 2 Multi-Core Test: Yes Cores per Processor: 2 SMT (Multi-Threaded) Benchmark:No Processor Affinity: P0C0T0 P0C1T0 System Timer: 14.32MHz Number of Runs: 64000 / 640 < Processor > Model: Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz Speed: 1.83GHz Cores per Processor: 2 Unit(s) Type: Mobile, Dual-Core L2 On-board Cache: 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < Features > SSE Technology: Yes SSE2 Technology: Yes SSE3 Technology: Yes Supplemental SSE3 Technology: Yes SSE4.1 Technology: No SSE4.2 Technology: No EMMX - Extended MMX Technology:No SSE4A Technology: No HTT - Hyper-Threading Technolo:No Can anyone suggest anything? Thanks. Scott |
jt27, I didn't see the same update although I tried removing a different update from the 15th with no luck.
I will post the sandra report soon. Mine is a different situation than Scottbanger's. I've had the same set up working for years up until 2 weeks ago when I packed, moved to new apt, plugged in digi 001, and opened PT which is hanging at "DAE Loaded". That's it. I haven't changed/added anything since the time it worked. I'm on a winxp pro, p4 3gig, abit motherboard (dunno model), digi 001, le 6.4. I hope that's enough info aside from the report but there's really not much to tell. It literally is a case of it worked and now it doesn't. Thank you all for your responses so far. |
i think you'd be best served starting your own thread while providing your SANDRA report. laptop makes it different than original poster.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#16
BLEH!!! I didn't even check an obvious possibility. Loose pci card! Thanks mykhal c.
DAE Loaded hangs | dmichael | Windows | 0 | 07-13-2011 10:54 AM |
PT Hangs at DAE Loaded message | abt | Pro Tools HDX & HD Native Systems (Win) | 26 | 04-25-2011 06:32 AM |
New Dell Laptop hangs on "DAE Loaded" PT8 Vista | Neil Miller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-16-2009 03:30 PM |
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista | Scottbanger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-18-2008 10:04 AM |
PT hangs on startup at DAE loaded | justmull1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-20-2007 06:48 PM |
