oktava mk 012
Hey, this is probably a dumb question. I've been recording thru my mbox for a while, i use a condenser mic, etc. however, when i attach my oktava mk-012 i get nothing, no signal.. i dont know if its something to do with phantom power or whatever, im just wondering if theres some dumb thing i forgot to do or if it depends on the type of mic, etc.
thanks. andy |
Re: oktava mk 012
so you are saying you do have Phantom Power on? and its still not working?
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
Re: oktava mk 012
yes, doesnt work whether phantom power is on or not. this also occurred with a mic a long time ago so i was just wondering maybe its a setting i don't know to tweak in protools or maybe just certain mics need something else to power it up.
Re: oktava mk 012
no it should power up just like any other Condenser you have. When you swap back and fourth between the condenser you normally use and the Oktava, does your normal Condenser work with the same settings? Have you tried the Oktava on a separate system or through a mixer to test it to make sure it is functioning properly? Don't forget to turn off Phantom before you plug or unplug the mics, people have fried their condensers like that before. Anyway, maybe you could do some more tests and let us know the results for more info on the issue.
Re: oktava mk 012
I originally got the oktava for my camera (dvx) and it worked just connecting it straight into the camera. i'll try turning the phantom power on and off when i change mics. thanks for the replies.
FT: Oktava ML-52-02 | JigMD80 | Buy & Sell | 0 | 12-25-2013 11:23 AM |
OT - Thanks for the Oktava tip! | qbert1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-02-2003 09:49 AM |
oktava 319 | J. FO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-02-2002 03:26 PM |
Oktava? Anbody Oktava? | spicyitaliano | General Discussion | 7 | 07-26-2002 07:02 PM |
anyone use the Oktava 319 | J. FO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-14-2002 11:29 AM |
