Old 11-21-2011, 03:22 PM
DJ FADE DJ FADE is offline
Default Bus/Send to TRACK not working
Sometimes, but not always, when using the SEND or BUS to TRACK option, it will assign the output (and input, on the track you're sending TO), but the paths will be greyed out and inactive. Anyone else running into this issue? How to resolve?
I LOVE this feature, super time-saver, but wish it worked ALL the time!
Old 11-21-2011, 03:30 PM
C C is offline
Default Re: Bus/Send to TRACK not working
How many busses are in your IO? Default setup is pretty full already maybe you are overfilling?
Just a thought.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 11-21-2011, 03:33 PM
Just a thought.
pretty sure i just have it set up with the default. and i'm on HD, so there should be a lot available! but that is a great suggestion. i will try to delete a couple and see if that by chance solves the issue!
Old 11-21-2011, 05:51 PM
strawb strawb is offline
same issue here. seems like a lot of the time PT doesn't want to give u fresh busses.
after choosing a new bus to track, u have to go into the i/o setup and UNCHECK the box next to the offender... the bus to track behavior definitely changed in PT10.
Send to Aux effects track not working Sharke Pro Tools 9 3 06-10-2012 12:31 PM
Audio Track lost it's Send to Delay Plugin on Aux Track Wolfgang_2 Pro Tools 9 0 03-14-2011 03:20 AM
Hybrid midi track to audio track via bus send is not working joshfrog94 Tips & Tricks 1 11-02-2010 07:46 PM
Send via DD not working Frank Kruse Aspera DigiDelivery 0 05-11-2009 03:47 AM
Send Reason Sequencer Track to ProTools Midi Track Andy Asfendis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-04-2004 01:58 AM
