Old 12-19-2001, 11:39 PM
Roy Howell Roy Howell is offline
Default Best ways to \'squash\' unwanted excess reverb in precut track?
These are doubled rhythm guitar tracks that I thought sounded perf at the time. I was so young (6 months ago), and didn't have the vast knowledge that I pretend to have today.
Actually, the guitars stop at these 'holes' here and there, and the reverb rings out too much(it's on the track).
How best can I keep the meat of the guitar, and try to hold some of that verb back? (Limiter, compressor...?)
Thanks, Roy
rh music
Old 12-19-2001, 11:43 PM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
Default Re: Best ways to \'squash\' unwanted excess reverb in precut track?
If you want to cut the reverb out of the holes I would try a gate. Adjusting the gate timing will effectively adjust the reverb tails in the holes. It won't do anything to reduce reverb where there are no holes though.
Mike
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Old 12-20-2001, 01:41 AM
Thanks Mike,
Should have known you'de come through for me. I thought about EMailing you, but I thought I'd give you a break (LOL).
Thanks, Roy
rh music
Old 12-20-2001, 07:09 AM
Mark_Knecht Mark_Knecht is offline
Roy,
If there are a lot of holes, then Mike's gate might be the best way to do this. If it works, that cool, but I think the other problem that could be created is what the gate might do in the middle of the phrase if it cuts in at all. You may find yourself trying to balance the whole thing.
If you're looking at just a few holes, I'd prefer to use the volume and mute automations, probably drawing them in by hand.
I often have to do this with my poor guitar playing. I'll get through a phrase corrctly, but get a little extra note or some other junk afterwards that I want to remove, so I have to take it out this way.
Cheers,
Mark
Old 12-22-2001, 07:05 AM
IOP Drummer IOP Drummer is offline
Use the gate/expander plug with the key filters set to ONLY LET THROUGH the pick noise, or attack of the guitar. Set your range to -6 or so and your threshold, attack and release times accordingly. This should effectively 'turn the verb down' when there are pauses or breaks, or even long notes {if the threshold is set right}. If this doesn't work but you want it to, you can copy the guitar track over to another track and eq it like crazy where the attack is. You can even hard gate ot on the copied track (optional) then use it to key the original gate, with the same setting as I said above. If you're only doing the breaks, why don't you just do a fade?
Mike Blanchard
Engineer
Old 12-23-2001, 07:15 AM
gerax gerax is offline
I would be very carefull in using a gate: if not set properly it could chop off something it shouldn't. To me it's a better idea to use volume and muting automation to crate a smooth more natural (and shorter) fade out for the reverb tail; I used this technique to correct the holes of silence in a few tracks that had a fairly noisy background, and although you can't completely get rid of it (otherwise you'll notice something strange in the continuity of the track) you can find a good balance (or compromise); I think a gate behaves more abruptly.
L.G.
Old 12-23-2001, 07:17 AM
Oh, I forgot: don't use compression at all, or you'll get exactly the opposite effect, as compression increases the average signal levell, thus bringing out ambience and lower level signals.
L.G.
Old 12-23-2001, 10:55 AM
Thanks ya'll. Great advice...
Roy
rh music
Trimming off unwanted time at the end of a track Featherstone Pro Tools 10 13 09-18-2012 09:14 AM
unwanted noise in instrument track lechszcz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-01-2008 08:28 AM
15 ways to remove the unwanted noises from records : DORUMALAIA General Discussion 0 06-14-2003 08:20 PM
any ways to soak up reverb in live dialogue tracks? c-post Tips & Tricks 4 03-04-2003 11:44 AM
squash a waveform? Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-18-2002 09:23 AM
