Where are my conversion quality settings for "convert after bounce"?
Hey All,
Am I just Dumb or what? Go easy on my OK! Where are my settings to pick "tweakhead" when I do a convert after bounce? I have PT LE5.1. The manual says once I choose "convert after bounce" that I should be able to pick "settings" and get a dialogue box to get my "tweakhead" setting. There is nothing to pick after I choose "convert after bounce"? What's up wit dat! Help! Thanks in advance, Most Humble, Dave |
Re: Where are my conversion quality settings for "convert after bounce"?
You will only see these choices if you have chosen a certain file format in your preferences before starting a session. I can't remember which it actually is, but only one of them (your choices are AIFF, SDII, and WAV - I believe) will give you the oportunity to set conversion quality on bounce. You may have to do some trial session set-ups in order to determine which it is, because I can't remember. Sorry for being so vague, but I hope this helps you.
Due to budget cuts the light at the end of the tunnel will be turned off until further notice. http://www.gidakdigital.com |
You'll indeed only get this dialogue box when going from certain bit depth/sample rate to some others (won't go into details here).
Anyway you can always choose the general setting of your conversion: Setups->Preferences->editing->Conversion quality menu->your choice.
Some music?... http://tmweb.free.fr |
The convert after bounce options (Good, Better etc) has nothing to do with the bit depth. It only applies for samplerate e.g if you are going from 48k to 44.1k.
-Robert
www.extensivemusic.com |
Just to clear up any confusion that may have arisen from this thread, Robert U is correct.
Brent <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Robert U: The convert after bounce options (Good, Better etc) has nothing to do with the bit depth. It only applies for samplerate e.g if you are going from 48k to 44.1k. <HR></BLOCKQUOTE> |
Cool!
Thanks All! And no coments on my stupidity to boot, don't know if I could have passed up that open door! I was going from a 44.1k/16bit session to the same in a bounce. I now understand completely. Thanks again, Most Humble, Dave |
P.S., Digi, looks like a good thing to update the manual with! Some very simple, yet important information that could easily be spelled out in the manual.
Thanks, Most Humble, Dave |
"cannot save "XXXXXX" because while translating I/O settings" | tdawgg | Pro Tools 10 | 14 | 10-26-2013 02:27 PM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
What would be the "Best" or "General" Quantize default settings? | Norm Mix | MIDI | 0 | 07-10-2009 12:38 PM |
Should "Conversion Quality" be set as high as possible? | jmaulz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-27-2008 03:08 AM |
48K to 44.1 "Convert After Bounce" = Chipmunks? | bloodspoint | Pro Tools TDM Systems (Mac) | 29 | 08-30-2002 12:47 AM |
