#21
Re: Reaper rewire latency into protools
Hi people...
This is just Crazyyy what s happening to me, I started messing around with the Synchronize to external Time Code settings in Reaper (choosing "Asio Positioning Protocol" and checking "Start playback on valid time-code") and it seems to fix the problem. If I start playback again (and stop) all of a sudden I can hear (and feel with my controller) both VI's playing at the same time (with reaper's buffer size finally in synch with PT's buffer size). When I did the test today, I started rewire from scratch and observed that the synch problem arises when I change buffer size in PT, it seems that reaper is not following those changes (even though I see it changing in reaper). ....before changing buffer size there is no synch problem....ummm how 's that for strange?? Also, when I change the buffer size to 64 or 128 samples in PT and with "Synchronize to external Time Code" enabled I can hear a phasey sound while playing both VI's at the same time.... ...and.....Reaper is still getting out of synch for seconds and then come back to synch even with the new tweak I mentioned above...I will see if I can live with that! THANKS A LOT.....i m still up to discover what the hell is going on |
#22
Further reading has me interested to comment again. I think it could be faulty coding in one of your VI's, but that's a long shot. Try this. Do not start syncing Pro Tools and REAPER for at least one bar. In other words, start the entire project on your second bar (move all your audio and MIDI info back). I remember in earlier versions of Reason, it needed this time to get in sync...had something to do with compatibility and rewire (can't remember exactly), Maybe it will work with REAPER as well. I've also had a problem in the past getting a lot of tracks to play at once in REAPER period (on a DIGI 002R). Updating to a faster system with a lot more RAM and doing the 3g switch mentioned in the "i7 Builds" Thread seemed to have fully solved that problem. Also try this: whenever you change the buffer size in PT, close and restart REAPER. This should help to insure the system has changed the setting...this might be happening with REAPER as well...Remember when you change buffer sizes in PT, any plugin latency is also affected. Since rewire is technically a plugin, this might be the cause of your specific issue...(worth a shot anyway) Good luck |
#23
hi people, no good news, !
I thought that I found a solution but this has become very unpredictable.. I did everything you guys told me but nothing... I just tried and the project started in synch, but then I change buffer sizes and out of synch again.. I tried the external time code stuff but nothing either...DAMN IT!!!!!!!!!!!!!!! Thanks,,, |
#24
Sorry no good news.
This in an awful lot of troubleshooting for such a straight forward setup. The fact that everything works fine for you with Cubase and Reaper ReWire makes me think that your audio interface is the culprit with the setup with PT... especially considering it works with PT until the buffer is changed. I have used Reaper ReWire with M-P 8, and now PT 9 with the Profire 2626. This is how I work everyday. PT buffer can be changed back and forth with no problems. Perhaps someone more privy to the sync topic will notice this thread and chime in. Wish I could be of more help. |
#25
Ok People I gave Up!
I'm gonna have to continue my project without reaper. Back to bouncing all the time, deactivating VI's and all that out of flow stuff!! If someone could give me some ideas of a similar way/method to keep protools from crying when using several Vi's at the same time I would appreciated! I know of VEP pro but it's too expensive right now, and soundflower for mac but I am on PC.. Thanks a lot guys |
#26
Third party VI's just run so heavy in PT compared to how their VST version runs in something else. I just work in something else and export the audio to PT for mixing or vocal tracking.
URBAN MUSIC- (Hip Hop and R&B) |
#27
#28
Reaper ReWire and VE Pro use the VST format. This is a part of what make them great solutions. I'm really looking forward to the AAX format and how it will perform. |
#29
hey thanks Spenner, I thought that the number of processors to be used in my case would be 3, as I have 4, (always 1 less than the total)..
My real problem with VI's inside PT is when lowering the buffer size in the middle of a composition so I can record, even with just one VI open (kontakt) I start hearing that grainy/distorted pops and clicks ... that sucks, .... I have to disable everyone and bounce to audio so I can record and then back again to edit my original midi and so on.... kind of a hassle..! anyways , i will try the half the processors tweak to see how it goes Thanks |
#30
If you are using Kontakt mutitimbral with several patches, then depending on those patches, and how many, you could be simply experiencing the common issues that warrant the need for a VI Host. If it's just a few patches then I'd take a look at the system. Could you post a Sandra report? |
Reaper Rewire Latency Issue | dougdude9 | Pro Tools 10 | 4 | 09-17-2013 01:08 PM |
ProTools and Reaper rewire | johndaw | Pro Tools 9 | 8 | 07-24-2013 09:51 AM |
Rewire Reaper with ProTools for audio processing | Zarabozo | Windows | 4 | 01-21-2013 08:59 PM |
Protools + Reaper (Rewire) synchrony problem | Zarabozo | Windows | 4 | 11-28-2012 08:53 PM |
ProTools Rewire & Reaper | jayprotools | Pro Tools TDM Systems (Mac) | 29 | 11-30-2010 07:48 PM |
