Old 05-02-2005, 01:36 PM
cliepe12 cliepe12 is offline
Default mBox and CPU
I just went from a dual 1.25 G4/001 setup to a Dual 1.8 G5/mBox setup with the hopes of using the mbox for pro tools and then getting a different hardware interface like the 2408mkIII to run with DP.
When I load up sessions that ran fairly well on my old setup, my new setup can't handle them at all. I have my hardware buffer cranked, and I keep getting a "CPU usage is holding off USB audio" error.
I thought that I would get a track count/plugin performance improvement with this move. Am I out of luck? Am I missing something?
Chris-
Digi001 6.4, 10.3.3, Reason 2.5, Waves Diamond v4, Yamaha 01V96, Dual 1.25 w/FW800 - 1GB, 2x120GB
Old 05-02-2005, 01:40 PM
Slim Shady Slim Shady is offline
Default Re: mBox and CPU
Did you set your energy saver processor prefs to 'highest'?
Did you do all the OSX setup/troubleshooting steps in the stickied thread at the top of the forum?
Old 05-02-2005, 02:05 PM
Produce_Dept Produce_Dept is offline
I had the same problem when I upgraded to 6.9... Got rid of my MBox and just run my 002
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 05-02-2005, 05:05 PM
yes, all the usualy PT troubleshooting excersizes have been done. Are you saying that Mbox performance is much better in 6.7? How do I downgrade to 6.7? Also, is the OO2 a better perfomer than the mbox on your system.
Is there anybody getting decent performance out of an mbox?
I was routinly able to run 32 tracks with a generous amount of waves plugins on my 001 rig? Anybody doing that with an Mbox?
Chris-
Old 05-02-2005, 07:02 PM
My Mbox on Dual G5 2.5 is rock solid and I've never come close to maxing out my CPU. I use Waves, McDSP, PSP, Altiverb and more in very heavy sessions (32 tracks + several inactive, lots of busses etc.) I however have not upgraded from 6.4 so I couldn't tell you if there's a difference in 6.7 or 6.9.
So in system preferences->energy saver you've set the processor performance to highest? That usually solves the problem you're having from what I remember.
Old 05-02-2005, 07:25 PM
Well - I had good performance on my MBox with 6.7... when i upgraded to 6.9 - i had major CPU problems (the "holding off USB audio" error) I hooked up my 002 - and man, smooth sailing. The firewire interface allows me to utilize so much more of my CPU resources... Just my observations
Kurt Bullock
Old 05-03-2005, 05:13 PM
right. Is there any way to REALLY do a clean downgrade to 6.7 or 6.4 without doing a hard drive reformat?
Chris-
Old 05-04-2005, 10:03 AM
DigiTechSupt's Avatar
Yes, just do a 'clean uninstall' of Pro Tools.
From the Pro Tools installer, go to the 'Custom Install' page, click on the word 'Custom Install' and select 'Uninstall' from the drop-down menu, then click the 'Uninstall' button. You will be asked if you want to do a 'Safe' or 'Clean' uninstall - choose 'Clean'. After uninstalling, restart your computer and then install the version of Pro Tools you wish to revert to.
Avid Audio Tech Support
Support FAQ
Old 05-04-2005, 10:03 PM
thanks Digi!!
I downgraded to 6.4 and have a much smoother running Pro Tools setup. Any word on why 6.9 and the Mbox don't get along and perhaps if there is a fix coming soon?
Chris-
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: Haezel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2011 02:58 AM
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2008 01:03 PM
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2006 08:18 PM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
