Old 10-12-2017, 10:23 AM
subwoof subwoof is offline
Default Premier OMF Audio Distorted
Anyone noticing OMF's from Premiere 11.1.2 is putting out distorted audio? I have 3 projects from 2 different studios that have had that problem in the last 2 weeks. It is obvious on the 2 pop, which sounds squared waved.
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 10-16-2017, 08:17 PM
Nathan W. Nathan W. is offline
Default Re: Premier OMF Audio Distorted
Yes. I've noticed this as well, have not been able to trace where the issue arises though.
Old 10-17-2017, 11:55 AM
Thank you! I was starting to wonder if anyone else had noticed this. Maybe someone from Adobe will respond.
Old 10-21-2017, 06:04 AM
trevora trevora is offline
I'm an occasional lurker - picture editor with access to PP2017.1.2 and 2018.0.something - happy to do any tests for you.
I do think that the PP OMF burns in any levels changed - and there's multiple places to adjust gain in PP.
I've made a test sequence of test tones and exported an OMF and AAF, with embedded audio. File is here
Track layout is:
A1 - mono, A2 - standard, A3 - adaptive ('standard' is default for PP)
Clip layout is track ident then sweep (about -6dB)
Gain layout is
00.00 - Unity
01.15 - Clip Gain +6dB
02.30 - Clip Mixer Gain +6dB
03.45 - Track Mixer Gain + 6dB (keyframed)
OMF is 16 bit (default, there is an option for 24 bit)
PP message is:
Make sure your Pro Tools settings match the export settings.
Check below for error messages
Start Time is: 00:00:00:00
ProTools Offset value is: 0:0.000
Frame Rate is: 25.00 fps
You can set this in Track Offset Options in Pro Tools.
AAF is not 'split to mono' (default, there is an option).
PP message is:
The AAF file "/Users/rmbp_july2017/Desktop/DUC Exports/PP2017.1.2 AAF non mono EXPORT.aaf" could not be exported completely and/or accurately, as logged below:
Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 1" (#1594086), Position: 3696, Time: 00:02:27:21) because it is not supported. Effect was ignored.
Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 1" (#1594086), Position: 3696, Time: 00:02:27:21) because it is not supported. Effect was ignored.
Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 2" (#1594086), Position: 3771, Time: 00:02:30:21) because it is not supported. Effect was ignored.
Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 2" (#1594086), Position: 3771, Time: 00:02:30:21) because it is not supported. Effect was ignored.
Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 3" (#1594086), Position: 3840, Time: 00:02:33:15) because it is not supported. Effect was ignored.
Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 3" (#1594086), Position: 3840, Time: 00:02:33:15) because it is not supported. Effect was ignored.
Hope that may be of some help in your diagnosis
HTML code is On
Distorted Audio in 10.1.1 Rubicon Pro Tools TDM Systems (Mac) 10 04-11-2012 10:53 AM
Premier on PC->PT on Mac Audio issues Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2005 10:21 AM
Distorted audio from OMF berk Post - Surround - Video 3 05-14-2005 09:18 AM
Distorted audio from Headphone amp! Tedmod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-09-2004 03:25 PM
distorted audio Ricco Pro Tools TDM Systems (Mac) 2 08-15-2000 03:26 AM
