Strange negative value showing in timeline
Hi Guys, I have strange Timeline behaviour
ie; after opening a stored session (see screenshot attachment) The timeline figures are showing about one hour difference - between the Bar & Beats timeline , and the minutes and seconds timeline Shouldn't they both be the same (ie; both beginning at zero) ? My song start time: begins at 0.00.00 Minutes (zero) - while the Bars & Beats timeline at the same location is showing negative -1798 Bars? Q - How can I change the timeline value for the Bars & Beats timeline to also begin at ZERO ?
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's |
Re: Strange negative value showing in timeline
Set grid to Bars|Beats and put the cursor where you want Bar 1 (or Bar 0) to be. Then go to the top menus Event->Renumber Bars. Set the current bar/cursor position to be the desired bar.
Scott Gatteño |
I don't see a Song Start marker in that screenshot - probably your Song Start is way down the timeline at 0 bars. As noted above, you can just renumber bars, but you should probably move your Song Start to 0 if it's not already. And...there's nothing strange about negative bar numbers; perfectly legal in all DAWs.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
This worked, thank you kindly Scott
All is working now. Thank you Kindly Rich
The only problem with moving the Song Start marker after already working on a song is that any tracks that are in tick mode may have their audio or MIDI data shifted.
Scott Gatteño |
How Do I Remove Negative Bars From The Timeline | DrewHarrison | Getting Started | 1 | 09-13-2020 02:41 PM |
Video repeating itself on timeline. Very strange. | PPM6 | macOS | 3 | 10-02-2012 08:39 AM |
Regions not showing on Timeline when Import Session Data | migbook | Pro Tools TDM Systems (Mac) | 4 | 03-18-2011 01:51 PM |
Strange behavior related to timeline | deardaddy | Post - Surround - Video | 5 | 04-13-2006 08:52 PM |
Creating a Negative Timeline | Hive Guy | Pro Tools TDM Systems (Mac) | 2 | 01-09-2006 02:22 PM |
