Old 10-31-2020, 07:30 AM
critictalk critictalk is offline
Default How to connect 192 I/O to CP950?
Got the answer, thx all!!!
Old 10-31-2020, 08:54 AM
mgoorevich's Avatar
mgoorevich mgoorevich is online now
Default Re: How to connect 192 I/O to CP950?
It utilizes an rj45 connector for gettin a standard AES signal.
The 192 io uses Tascam standard pinout for both AES and Analog I/O
https://www.ebay.com/itm/133459195784
Pay attention to that cp950 analog out (and in) is using Yamaha standard for db25 pinouts too.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-01-2020, 10:13 AM
Brandonx1 Brandonx1 is offline
Isn't AES67 IP audio? I don't think you can use that adapter to AES67, right?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-01-2020, 10:46 AM
I’m not sure.Btw, my 192 output is in digital
Old 11-01-2020, 11:08 AM
The initial question seems confused. Are you trying to do Atmos or just 5.1 or 7.1 surround?
If 5.1 or 7.1 the Dolby box supports AES-3 aka AES/EBU on the RJ45. So you just need a physical cable converter like mgoorevich replied earlier.
If you are trying to do Atmos with that box it's not going to be AES-3.
Old 11-01-2020, 11:14 AM
Well, just 5.1 and 7.1
Old 11-01-2020, 11:18 AM
So you already have your answer.
HTML code is On
How to Connect 3 or 4 96I/O's... The Monk Pro Tools TDM Systems (Mac) 12 02-05-2013 03:30 AM
one MC mix sometimes won't connect Led Artist Series 14 03-21-2011 03:41 PM
How to connect everything? Jay_Bee_Cee ProControl, Control|24, Command|8 3 01-23-2007 07:38 PM
How do I best connect these? Eiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-05-2004 04:55 AM
To connect or not to connect niros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-08-2003 03:27 AM
