Multiple Audio Clip Duration - Same track
Hi there!
Here's the big question! Does anybody know how to select multiple audio clips in a same track and to shorten or lengthen their durations by a same fixed or relative time value by moving their start or end boundaries? Thanks!!!! |
Re: Multiple Audio Clip Duration - Same track
The only method I'm aware of (though a clumsy one) is to select multiple clips with "Object grabber" tool and trim them by "Command"_"+/-".The clumsy part is that you have to click all the clips individually to select them.
Thanks guys! That's been really helpful!
If you select one select one clip. Command or CTRL+A will select all other clips in the same track
Set Duration of Empty Consolidated clip ... | ptfigg | macOS | 5 | 08-22-2013 11:04 AM |
Fades Multiple Audio Clips - Same Track | tomsaboia | macOS | 0 | 09-11-2012 10:14 AM |
Cant run multiple instrument plugins on the same audio track | DANIELHENDRICKS | macOS | 1 | 01-29-2012 11:47 AM |
Using elastic audio with multiple track groups | neil conti | Pro Tools TDM Systems (Mac) | 4 | 10-31-2009 04:59 AM |
importing multiple audio files into the same track? | tokolosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2009 01:07 PM |
