any benefits to upsample from 16bit 44.1 to 24bit
any benefits to upsample from 16bit 44.1 to 24bit 48k...
original tracks are from 16bit 44.1k or recorded by user at different quality, the latter will have some processing like EQ and reverbs applied to. Thanks RayS
ray |
Re: any benefits to upsample from 16bit 44.1 to 24bit
What is the nature of the project? (CD, music for TV or film, etc.)
At what stage is the project? (What's next?) Describe your rig, please.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Its SFX tracks for live surround stems etc... This is how I have receiced the files from another ProTools studio...some of the original material was at 8 bit (yes you read correctly 8 b i t) then the whole thing was upsampled to 48K 24bit ...to use hi sample reverb algorithms and editing.....but then they just heard that this was a waste of time went noutboard gear?? but left everything at 48k 24bits etc...and here we are with the questions.... So what can be gained from doing this at all....the most quality will be from the original depth and rate even if you add the million dollar reverb plugin....right??? I would think that garbage in a jewel box is still garbage ???javascript:void(0)
just trying to settle this way of doing things for the sake of sanity or higher learning. Thanks Ray
ray |
The quick, untechnical answer is that it won't improve the sound of what you have already. It may make a difference if you are going to apply some processing to those tracks by way of plug-ins or combining/mixing/bussing tracks together. It will improve the sound quality of anything new that you record to the session via analog input, or by digital input if the source is at 24 bit.
www.clifnorrell.com |
Reminds me of the CSI trick where they take the crappy black & white securicam picture and 'sharpen' it so they can identify the criminal and read the licence plate. Upsampling to 24-bit is like using a Fineliner to draw a big block letter on a billboard - you still get the big block letter, it's just made of thinner lines!
Sonny Keyes Ricochet Audio Toronto
Sonny Keyes Toronto http://www.sonnykeyes.ca Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20 Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10 |
16bit vs 24bit | TwinSnakes007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-14-2008 06:39 PM |
44.1? 48? 96? 16bit? 24bit? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-25-2006 02:22 PM |
Going from 24bit to 16bit | Glenn75 | Tips & Tricks | 3 | 03-21-2005 04:32 AM |
Convert 24bit to 16bit? | JEromeo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-16-2004 07:26 AM |
Best way to get from 24bit/44.1 to 16bit/44.1? | Tone | Pro Tools TDM Systems (Mac) | 7 | 11-09-2003 11:27 AM |
