Bad Production Audio
Hey there!
I am encountering a problem with some low level distortion on a coup[le of interviews. The wave form looks clipped so i am assuming that the signal going to the camera was being limited. The distortion is not terrible but bothersome the boom channel sounds a little more usable than the lav. Any suggestions? I know that its pretty much c@#p in c@#p out but I want to know how some of you deal with this prob. Thanks RPM |
Re: Bad Production Audio
Hello Montoya,
I'm afraid there's not much you can do about this problem, because the origin of it is in the mic preamp gain. It is a common mistake inexperienced operators make, to clip the preamp's input and try to solve the problem on master fader - the result is always distortion, regardless of recording level. You can hide the problem with some carefull EQ (probably in lo-mid area). I've been sometimes lucky with Steinberg's De-clicker. And, yes, boom mic almost always sounds better than lavs. Branko |
Concur- I almost always use the boom instead of the lavs...Death to LAVs!!!
-p |
I had a problem with some overloaded interveiws that got vastly improved by some creative use of the limeter... I can't take credit for coming up with this but if your problem is becaus the file is cliped then this might work for you. You limit the file to a bit below the (cliped) peaks with a soft knee compressor. if you get the settings just right you end up rounding the sarp edges of the clips and the perceved distortion almost disapears.
Good luck SK |
Mac or PC, which is the winner for audio production? | pcmusicpro | Windows | 14 | 08-14-2011 09:40 PM |
Weak Production Audio | Grey | Post - Surround - Video | 7 | 08-23-2010 03:47 PM |
DV Audio Clean-up Post Production | deand | Tips & Tricks | 0 | 03-31-2008 08:03 AM |
Clipped Production Audio | Jonathan Greasley | Post - Surround - Video | 14 | 06-09-2007 01:41 AM |
EMU Audio Production Studio VS Digi 001? | moe green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-08-2001 08:22 PM |
