dc30
I'm using a dc30(not plus) and can't seem to get a good image. Scrolling with the video in pt doesn't work. It waits until I stop to catch up. I've seen images done with a dc20 card that look far better and even scroll. I get lots of dropped frames and have tried everything listed in the Miro pages. Can anyone out there help. Please!!!! Thanks, Craig
Re: dc30
Sounds like a driver problem. I use a DC 30 and am quite pleased with its performance. Make sure you have the latest drivers (from the miro web site-sorry don't have it handy, but is pretty easy to find...) The drivers which ship with the CD may not work at all (at least for NTSC).
I capture at 800 to 1000k/sec, 320/240 (in Premiere). I also prefer to use an internal drive in the Mac, as its data transfer rate is faster. Also, make sure you have Quicktime 3.0 or higher installed. As I recall, the miro CD will install Quicktime 2.5, which will not work. Good luck! Bob
Save early and often! (or once a day whether you need to or not...) |
Re: dc30
Thanks for the info. Got the latest drivers etc, and finally got pt to scroll nicely. I'm still having pix quality problems. If I use 800K to record with, my time code window ghosts badly. And the picture is fuzzy. If I go down to 500k then the window is good, buit the rest also suffers a bit in quality. Any idea what's going on. I can't use this with clients. The pix is embaressing. I record on the internal drive to my 9600, 200. More help would be appreciated. Pinnacle charges out the ear just to get help. Help please! Thanks, Craig
Re: dc30
I'm just guessing that the 9600/200 might be a bit too slow. I'm using 1000 kb per second on a 9600/350, and it looks pretty good.
Lee Blaske |
PT6.0, OSX, & DC30+ | emf1138 | Pro Tools TDM Systems (Mac) | 2 | 06-12-2003 09:55 PM |
miro DC30 vs DC30 plus | mixtery | Post - Surround - Video | 2 | 11-12-2002 08:33 AM |
Difference between Miro DC30 and DC30 Plus | [email protected] | Pro Tools TDM Systems (Mac) | 1 | 04-15-2002 09:26 PM |
Miro DC30 vs. DC30+? the diff? | mixtery | Tips & Tricks | 0 | 11-19-2001 06:13 PM |
Miro DC30/DC30+ | MikeC | General Discussion | 4 | 11-16-2000 09:48 AM |
