Re: Can Offline Bounce be trusted...?
Unfortunately we can’t defy the laws of physics. Outboard inserts and MIDI triggering HW instruments can never be captured in non real-time. Just what’s ITB. I only had an issue once with offline bounce. Turns out it was a plugin issue and was also happening in real-time. Didn’t pick up on it at first and thought it was the offline render. So, the short of it, IMO, you can trust it. But, I’d encourage you to do some tests and see if you notice anything. The reality is, if there is an issue, then it’s technically broken and it’s a bug that needs to be fixed. There’s no reason the feature should not work as advertised. Sent from my iPhone using Tapatalk |
What Sardi said.
You CAN offline bounce with AAX-DSP plugins and VIs
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
I completely understand WHY you can't offline bounce with outboard and MIDI, even though I didn't do well in physics in high school. Just confirming. But I didn't realize you could use AAX-DSP plugins when doing offline bounce. I thought they got automatically bypassed?
-------------------------------------------- 2009 Mac Pro 5,1, PT 2021.3.1, HDX, Mojave, RX 560, Apogee AD/DA-16X, HD I/O 8x8 |
In my experience offline bounce works great in Pro tools. The only time I’ve had problems with it was because of plugin bugs. I would take the time to figure a out which plugs are problematic and find a work around. Some times VIs can do weird things too.
And yes DSP plugins are included in offline bounce they just get processed as the native version offline. |
You CAN technically do an offline bounce with outboard inserts. It will just run real time so no benefit
~Will |
I've been offline bouncing since the option first appeared and although it could be a little sketchy in those days it seems to be relatively solid.
However, I will ALWAYS online bounce an important track, and still listen back to the entire thing after the file is created. Even if it's 99.9% reliable, I don't want that .1 getting through at a bad time. |
~Will |
Over the years, I've noticed a *few* dynamics plugs (particularly ones that boast of "analog" modeling) don't respond exactly the same in online vs real-time. No, I haven't compiled a list, but there's a couple that I watch out for.
That said, I find offline bounce reliable, though I would never send anything out without listening to it first.
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 | andresix | Pro Tools | 13 | 11-19-2021 07:03 PM |
Bug of the week: HDX offline bounce different from online bounce | XJENSEN | Pro Tools 2020 | 25 | 02-24-2021 10:17 PM |
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct | Skwaidu | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2015 03:55 PM |
Offline bounce vs. Realtime bounce significant differences | Mano | Pro Tools 11 | 13 | 05-29-2014 05:58 PM |
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
