Windows 7 64 bit and pro tools 9(002 rack FW)
I am having some problems with my pc(amd x4, windows 7 64 bit) and digi 002((pro tools 9). Pro tools starts and runs but I get crackles. It sounds a bit like a clock problem. Is there anyone who has the same problem? Pro tools 9 and digi 002 rack runs very good on my mac so I think it´s just a matter of settings with windows 7. I also tried pro tools 9 (digi 002 rack) on xp, same problem there. Pro tools 7.3 works great with my digi 002. Thanks Kai... |
Re: Windows 7 64 bit and pro tools 9(002 rack FW)
if there's a lot going on in your session, like even one complex reverb it might be the buffer size set to low for you computer to keep up.
try increasing the buffer size. other than that, you didn't give us enough information. at the top of this site Help us Help You - READ THIS Before Posting! |
It´s not the buffer size. It also sounds like a clocking problem. What exactly do you need to know about my setup? Pro tools 9.03 digi 002 rack (firewire) latest driver from avid (digi002/003rack_v9) Windows 7 64 bit Like I said Pro Tools 7.3 runs flawless with the same setup. I could imagine something stupid like uninstalling internet explorer 8 could solve my problem. It´s also strange that I seem to be the only one with this particular problem. Unfortunately my support period is over and till now I only used my mac. |
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
Ok Thanks I will try but I guess it´s a digi 002 problem. Forgot to tell you that it works with my mbox 2...
My vote is your 002 rack is fine. AVID has a driver issue. you mentioned it runs well under version7, that absolutely has different drivers. I had a 002 rack too and got the exact same results as you. In fact, I think I did all the things you did and probably more! Looks to me like the only difference between us is our processors, I think you are AMD, I am intel i7 950.
I had unusable sound quality and I purchased techsupport from AVID and.. My issue went unresolved. The last tech I spoke to mentioned I could escalate my case because they've been thru everything they know to do. I chose not too. for me my options was 1) wait for avid to release new functional drivers. 2) get new hardware that works. I can't run a studio with pops in the audio nor do I have time to wait for avid. So I chose option 2. and I kissed all my issues goodbye! and also I might add that I've been thru all those win7 optimazations and they didn't resolve all my issues. (maybe only slightly better). I purchased a RME audio HDSP card with an external multiface sound interface which functions electronically identical to the 002 rack in terms of digital & analog I/O. Its an expensive solution... but at least it is a solution. When things stay broke, its even more expensive when you consider the fact that you bought ProTools and can't use it. |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Re: Windows 7 64 bit and pro tools 9(002 rack FW)Help
Hello, I'd like to chime in on this one as I have been watching it for awhile for some change in status but none has come.
I am having the same problem as described at the beginning, I have checked all my settings, pc optimizations, pro tools 9 install, pluggins etc. The best I can figure there is a process running in the background that needs to be removed or turned off. my Sandra Report SiSoftware Sandra Computer Model : Gigabyte Technology Co., Ltd. EG45M-UD2H Workgroup : WORKGROUP Host Name : owner-PC User : owner Processor Model : Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz Speed : 2.67GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte Technology Co., Ltd. EG45M-UD2H BIOS : Award Software International, Inc. F3 04/09/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 Chipset Model : 5208 2E20h Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : CE M3 78T2953GZ3-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : CE M3 78T2953GZ3-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : CE M3 78T2953GZ3-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : CE M3 78T2953GZ3-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Radeon HD 4300/4500 Series (SM4.1 600MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor OpenCL Processor : ATI RV710 (160SP 2C 600MHz, 256MB) Storage Devices 2 ST3160318AS (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 149GB (C:) 2 ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) 2 ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) PIONEER DVD-RW DVR-218L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 28MB (F:) Disk : 2GB (G:) Logical Storage Devices System Reserved : 100MB (NTFS) Audio (D:) : 466GB (NTFS) @ 2 ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Sample (E:) : 466GB (NTFS) @ 2 ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (C:) : 146GB (NTFS) @ 2 ST3160318AS (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Audio CD (F:) : 0bytes (CDFS) @ PIONEER DVD-RW DVR-218L (SATA150, DVD+-RW, CD-RW, 2MB Cache) Reason 5.0.1 (G:) : 2GB (CDFS) @ Disk Peripherals LPC Hub Controller 1 : 5208 3A16h LPC Legacy Controller 1 : T2 87-18 Audio Device : 5208 3A3Eh Audio Device : 5963 AA38h Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : 5208 3A20h Disk Controller : 5208 3A26h Disk Controller : 5208 2368h USB Controller 1 : 5208 3A37h USB Controller 2 : 5208 3A38h USB Controller 3 : 5208 3A39h USB Controller 4 : 5208 3A3Ch USB Controller 5 : 5208 3A34h USB Controller 6 : 5208 3A35h USB Controller 7 : 5208 3A36h USB Controller 8 : 5208 3A3Ah FireWire/1394 Controller 1 : 5208 8024h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Photosmart C7100 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter 1 : D-Link DWA-552 XtremeN Desktop Adapter (802.11n (HT), AES-CCMP, 130Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 3.7 |
Hi I used to get a load of crunchy digi noise when I had SPDIF as an input on any track with the SPDIF source, a Focusrite pre, powered off. When I changed the input to anything else, or powered the SPDIF source,the crackling noise stopped.
No spidif going on here. Just my 002 rack. FireWire. With most current drivers
Pro Tools 9.0.6 Update - Eleven Rack - Windows 7 Results | Benoni | Eleven Rack | 2 | 12-01-2011 11:56 AM |
HELP!!! 002 Rack, Windows 7 64 bit | theregentblue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-01-2010 05:22 PM |
Eleven Rack Update for Pro Tools 8.0.3 Windows Systems | Avid | Technical Alerts | 0 | 12-29-2009 07:50 PM |
Will the 02 rack require 6.x for Windows? | Steve Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-23-2003 01:25 PM |
002 rack windows pt 6.1 | werds mekani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 06-09-2003 07:44 PM |
