Time-compression artifacts
Am I dreaming, or has the time-compression in PT 9 taken a quality hit compared with earlier versions? I used to do overall compressions to bring an announcer read in from 31 to 30 seconds on a radio spot and I couldn't hear problems EVER, and now I can shave 10 frames off a slightly overlength announcer and I hear big clicky artifacts. Maybe it's just a coincidence of voice types or something, but I've noticed it three times in the last couple of weeks. Anyone else?
Sonny Keyes Ricochet Audio Toronto |
Re: Time-compression artifacts
You probably know this! but you can assign any pitch shift plugin in prefs to be used in the TCE tool. I have assigned Waves time shifter, i find it better. Chris
Just the opposite for me! I've used TCE tool with much better results on dry vox. Easily squeeze almost 10% without issue.
For HEAVY time compression/pitch change I use an external app., Prosoniq's TimeFactory 2 http://www.prosoniq.com/editing-products/timefactory-2/
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
I would recommend Serato Pitch n Time Pro.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
X-Form for me, (as long as you're charging by the hour!)
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
X-form +1
But... when changing tempo on drumloops I use Time Shift and Varispeed to just pitch it up or down without any stretch algorithm involved. Best quality that way but when "stretching" longer files, lets say a whole 3 minutes drumbounce I get several nasty digital spikes in the processed files, it is not an overload thing, can be a spike on a place which before was dead silence... If I undo and apply the settings again, the spikes will occur on the same places... Am I alone with this?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Time compression / expansion | Steven Kirk | Digidesign Hardware & Software | 3 | 06-20-2002 02:37 PM |
time compression | funkdoctor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-03-2002 02:10 PM |
Time stretching and artifacts | maphew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-07-2001 11:13 PM |
Serato Pitch'n Time -artifacts? | Zep Dude | Tips & Tricks | 4 | 05-28-2001 05:11 PM |
Time compression | coaster | Pro Tools TDM Systems (Mac) | 4 | 10-22-1999 06:45 PM |
