Any Help?? Could not complete open session ..error
HI Friends
This Time I'm sincerely in troubles... After working all the afternoon on a paid mix session my rig decided to crash while I was doing some moves (G5/HD3) , so when I restarted the computer and try to reopen my session this is exsactly what I got: Could not complete the Open Session... command beacuse an error ocurred while reading the document and to my bad luck the sessions backup's was not activated !! I also tried to open another session and import the Data from the session that I was working on and the exact same thing happened again... I alrady try the FAQ and there is only one answer that relates with video; not my case... :-( any help will be very much appreciated thanks!
Fernando |
Re: Any Help?? Could not complete open session ..error
When you opened a new session and tried to import data, did you try one track at a time? and did you try with un-selecting data!! in the "data to import" pull down box. try with just the audio and not the plugins etc. other things to try... trash all the prefs Digi/DAE/pro tools from the prefs folder located in Mackintosh HD/users/your name/library/prefeences, get them ALL, then reboot. Also delete ALL Digidesign database files from all harddrive partitions. Chris
HI Chris
thanks for you help but again after trashing all the data bases and DAE prefernces still did not open the session.... As far as Importing the the Data from a new session it does the exact same thing. when I go and select my bad session imediately responses with the same dialog: can't open the session an error has ocurred.......... anyways thanks so much !
Fernando |
song will not open, could not complete the open session commandbecause...while transl | SNAPPER | Pro Tools 9 | 6 | 02-11-2017 11:32 AM |
Could not complete open session because error translating tracks | spiritfallrecording | Pro Tools 10 | 3 | 01-21-2014 08:31 PM |
Error Msg "Could Not Complete The Open Session Command *DELETED* | KTKonflict | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-28-2008 06:38 AM |
error "could not complete open session command.." | Stoneroses63 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-25-2006 05:30 PM |
Could not complete "Open Session" error | hookiefree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-12-2004 10:34 AM |
