BNR (DINR) TDM not passing audio
Hey All,
Sorry I didn't come up with a clever pun vis-a-vis DINR - I'll leave that to you. Got BNR as part of the recent Massive Pack, and I'm trying to use it for the first time. Inserted it on a audio track (first slot, TDM), and...nothing. No sound coming through. Tried to "learn" noise signature; no evidence that it's getting audio. Bypassing the plug still blocks audio. Disabling the plug allows audio through. Tried several tracks. All other plugins (around 100) are working. Any thoughts? Thanks, Jamshied Mac Nehalem 8-core 2.26 12GB RAM HD3 Accel Mac OS 10.5.7 PT 8.0.1 BNR TDM 8.0 |
Re: BNR (DINR) TDM not passing audio
Total noise reduction?
Sorry, couldn't resist. |
I'll check it on another session, and then reinstall, thanks. DINR AudioSuite is working, by the way. I guess that uses the RTAS component in the plugins folder.
Tried a different session (at a different sampling rate) - same behavior. re-installed DINR from the version on Digi's website - same behavior. To wit, no audio passes through when the plug is instantiated, even with the plug bypassed.
All other plugs working perfectly. DINR AudioSuite works as well. Digi, any thoughts? |
Hi Jamshied,
sorry, I can't help either... But: I wouldn't use too much time to solve that problem. BNR is a very, very old noise reduction plug (I guess from 1996!). I gave up using it some years ago because I never reached satisfying results. But Digi is clever enough to keep the nominal price high (still 1000 Euros in Europe!!!). So your savings seem to be higher when buying a bundle like Massive Pack. Just my 2 cents Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
Hey Mark,
I actually just used the AudioSuite version, and got good results. I know there are better things out there, including Waves Restoration and even Digi's new offering, but considering the price I'm happy with what DINR can accomplish. If only it would work... By the way, I installed PT 8.0.1cs1 - no change in DINR's non-cooperation. |
you should be able to get it to work by uninstantiating it and then re-instantiating it.
Thanks, tried that - both un- and re-instantiating, and dis- and re-enabling. It seems it just doesn't work. Is the OS right (10.5.7) for the versions of PT (8.0.1cs1) and DINR (8.0)?
Have you tried trashing preferences yet, so that all plug-in data can be re-cached?
No audio passing through Mbox2 Pro | wrkingclassoi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-29-2008 11:43 AM |
core audio conects , but no audio passing threw | audiomania | Pro Tools TDM Systems (Mac) | 2 | 08-23-2006 07:41 AM |
busses not passing audio WTF!? | jash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2005 06:41 PM |
882/20 input not passing audio | Craig Woolard | Pro Tools TDM Systems (Mac) | 1 | 07-17-2000 10:51 PM |
Am I Passing 24bit Audio or What | zeeman | Pro Tools TDM Systems (Mac) | 4 | 10-12-1999 10:34 AM |
