Bounced Files are Silent
What would cause my bounced songs to be silent? I can hear them as they are being bounced.
Re: Bounced Files are Silent
Bounce source is set to the wrong PT output? Are the bounced files actually silent or do they look silent?
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 |
When you import the bounced files back into Pro Tools, can you see the waveforms or there's nothing at all visually?
MacBook Pro - OS X 10.6 - Pro Tools LE 8 - Mbox 2 Drone / Ambient / Experimental |
There is no waveform. Also, I've changed to using my Mackie interface through spdif
2hip, you have not described how you actually do the bounce process. If it's plain Pro Tools / file menu –> Bounce to –> Disk... make sure you select the correct output in the Bounce Source menu. That would be the output or bus where you are routing all your tracks' audio to.
If you're still having trouble you should provide a little more info on how you're bouncing.
BFX
Thanks, it fixed the problem. |
Pop at the end of bounced files | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 11 | 07-25-2011 06:42 PM |
Audio Files folder (silent/old files) | Jasari149 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-19-2009 08:51 AM |
Bounced files end gets cut off | breakie | Pro Tools TDM Systems (Mac) | 8 | 05-25-2005 01:26 PM |
Bounced files | shameeta | General Discussion | 4 | 11-09-2003 07:36 PM |
PT Bounced files unrecogniseable | Emile Goyette | Pro Tools TDM Systems (Mac) | 25 | 06-02-2001 11:36 AM |
