Old 07-11-2022, 10:32 AM
Eric Lambert's Avatar
Default Unwanted new behavior in 2022.6
If I'm editing MIDI on a track in Notes mode, then hit Control-Command-Arrow to switch into Velocity Mode, I'm immediately taken to the track whose name is highlighted, even if I have some notes on a different track highlighted.
I'm sure this is a preference somewhere, but I've never experienced it before. In the past, regardless of which track's name was highlighted, if I switched to Velocity Mode using the shortcut the view would not change -- it stayed on those selected MIDI notes.
Can someone point me to the preference I need to turn off/on?
Old 07-13-2022, 05:11 PM
take77 take77 is offline
Default Re: Unwanted new behavior in 2022.6.
Hi Eric,
Check to see if "Link Track & Edit Selection" is enabled.
Upper left, after the 12345, 3rd icon over.
Hope that helps.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 07-14-2022, 01:20 PM
Good find. It was indeed checked, but even after I unchecked that icon the behavior continues.
I'll dig a little deeper with these types of parameters -- I think you're onto it.
Old 07-14-2022, 06:49 PM
Darn, I was hoping that helped.
I was actually thinking having it enabled would help if it wasn't already.
How does it work having both the 2nd (Link timeline & Edit selection) & 3rd (Link Track & Edit selection) on?
Or just the 2nd one?
For lack of better words...
Actually, now that I reread your post I don't think I know what I'm talking about because you already have things in view.
Old 07-15-2022, 12:38 PM
I appreciate the help! It's an odd one -- I still don't know what preference parameter is forcing this to happen. Whatever it is, it's new behavior.
Old 07-15-2022, 07:07 PM
Glad to help! I'm now getting more the sense that this is new behavior after reading your post again.
Seems now would be an opportune time to submit a support case while MIDI is being given attention.
Old 07-17-2022, 10:27 AM
Am I the only one experiencing this behavior with default Preference settings?
I'll check to see if EuCon is somehow forcing this to happen. Maybe it's a setting in that app.
Old 07-17-2022, 06:51 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Check out what I found in the new Keyboard Shortcuts menu....
When I set the command I think you want to the shortcut I think you were using, I see another command might be using your shortcut to do what you are observing!!!
Shifting key commands on us, shameless haha.... Hopefully you can figure this out for your own setup with this info...
File Type: jpg MIDI change velocity or fit track size to window.jpg (33.0 KB, 0 views)
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 07-17-2022, 10:09 PM
ZEUSS ZEUSS is offline
2022.6 is garbage. Revert back for midi.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
weird midi editor behavior in 2022.4/groove cell not well implemented ejsongs Pro Tools 7 04-30-2022 09:11 PM
Unwanted Buzzing niehausb Pro Tools M-Powered (Mac) 1 04-26-2009 10:54 PM
UNWANTED +5dB on DX BUS!!! laudisi Pro Tools TDM Systems (Mac) 8 01-24-2005 07:02 AM
