#21
Re: Collaboration with Pro Tools first?
No! That is not what drop box does, it inserts a virtual filesystem shim on your computer. when you record to that drop box folder it is doing whatever it wants shuffling blocks remotely or not. That degrades performance and has none of the file close/commit/flush to disk semantics a local file system does. You should not record to a cloud drive folder. But again it will work fun until it doesn’t.
There is no such thing as “just syncs” things might sync within some time period with high probability, they might not sync because of problems, and the issue is the users and Pro Tools not being able to know. Pro Tools thinks it’s writing to a filesystem, this filesystem shim is supposed to asynchronously make what is written locally appear in the web storage. Pro Tools writes a file thinks it is committed, on a normal drive it is, absolute 100% guarantee when done correctly the blocks of data are on disk. And if Pro Tools locally writes a bunch of files in the right way it knows they are committed on disk, together at that point of time. There is absolutely no guarantee that data ever makes it to cloud storage or that files committed at the same time, or in an order are written in the same time or order. This stuff is obvious if you have an idea what is going on below the covers, have ever written or used software to manage distributed data. You need to either accept what I am saying of not, I am not going to keep debating how this stuff works has fundamental issues that can cause problems. Last edited by Darryl Ramm; 07-13-2022 at 07:12 PM. |
#22
In my case I have a script that copies zip backup files to Google Cloud storage buckets. A different approach than Google Drive or Dropbox, but similar. |
Collaboration through Pro Tools Cloud | jamesleonard | General Discussion | 5 | 03-25-2018 10:47 AM |
Pro Tools | First & Collaboration | mandal | Pro Tools | Intro Discussion | 0 | 12-06-2016 10:02 AM |
Pro Tools First Cloud Collaboration? | jaxon.edwards | Pro Tools | Intro Discussion | 5 | 10-07-2016 12:42 PM |
Cloud collaboration vs real collaboration | midnightrambler | Pro Tools 12 | 13 | 06-11-2015 01:48 PM |
Pro Tools Collaboration Question | Wyn | Pro Tools TDM Systems (Mac) | 10 | 06-30-2010 03:24 PM |
