  #101
Old 06-24-2021, 12:39 PM
Tweakhead Tweakhead is offline
Default Re: Pro Tools 2021.6
Originally Posted by noiseboyuk View Post
Hey that's interesting. Presumably it doesn't work with (say) a stereo version of a plugin if I try to drag it to a mono track? ie is it smart enough to be able to automatically load the mono version?
yes, confirmed working with 3rd-party too. both directions.
except it doesn't intelligently apply this process to track presets, eg a mono plug-in chain saved and applied to a stereo track will result in multi-mono plugins on the stereo inserts - but dragging them off to a mono track, and then back again will make it stereo (if available).
  #102
Old 06-24-2021, 12:48 PM
arche3's Avatar
arche3 arche3 is offline
Originally Posted by musicman691 View Post
To answer a question I posed a few minutes ago yes PT 2021.6 installs and works ok (so far) on OSX 10.13.6. As always I made a bootable clone of my system before doing the install. I renamed the existing (before update) PT install to PT 2021/3/1 so the new install didn't overwrite it (I now have four PT installs). Did the update and drug in the modified ptcolors.txt file I've been using even before I first opened 2021.6 and it came up just the way it should with the new color customization working.
Sadly for as neat as what Avid did there's still a few things in my file that Avid missed that I and I think others that have my file have gotten used to and like (like inactive plugin insert fields being red).
The rest of the features in the new version I'll find in time but this color thing was paramount for me.
Ha ha!!!!! Awesome. I was hoping you would just install. I'm still on 10.13.6 as well.
Sent from my SM-G986U using Tapatalk
  #103
Old 06-24-2021, 01:17 PM
Rico618 Rico618 is offline
Hey everyone, as of today M1 is supported which is awesome! But I noticed that the CPU cores in the "System Usage" window has dropped from 8 cores to 4 cores. I don't have a lot of knowledge when it comes to that stuff, so I am just wondering why that has happened. I know the M1 arcutecture is "different" so maybe the 8 cores was never suppose to be there because PT wasn't supported yet? I don't know lol Just wanted to ask.
  #104
Old 06-24-2021, 01:50 PM
Watagushu2013 Watagushu2013 is offline
Originally Posted by MixerGuy View Post
I installed PT 2021.6
plus the HD driver (new one)
plus the Codecs LE (new one)
and tried to download (but could not download) the new drivers: DSX driver, CodecsPE - the My Avid repeatedly refused to let me download....
and then ran PT Ultimate 2021.6
and it seems to see my HDX cards
but is running only native, and i cant change any plugin to DSP (the old fashioned way)
plus it sees my HDX cards, but has ZERO load on them. zero usage
so how do i fix this?
Update: when I turn OFF hybrid mix engine - and restart protools - then it sees my HDX cards, and runs as expected.
So the hybrid engine (only) is NOT utilizing the HDX cards, but the system usage windows shows them, but all 100% unused.
thanks.
I think that what you are saying is how it works now.
Just open the mixer window and press the new thunder button for each channel that you want to put on the dsp chips.
  #105
Old 06-24-2021, 01:53 PM
Default Pro Tools 2021.6
Amazing how yesterday a 5.1 session in a HDX 3 was going half full and today the same session only uses 11% of host cpu without any DSP going thru the cards.
275 channels full of plugs, like 16 reverbs ( altiverbs, stratus, revibes,)
Wow!
  #106
Old 06-24-2021, 03:00 PM
noiseboyuk noiseboyuk is offline
Originally Posted by epm View Post
can confirm that it automatically switches to the mono version of a plugin if you drag it from a stereo to mono track, if a mono version is not available it will highlight red when you mouse over the mono track and give you an error saying there is no mono version available if you try to drop it there.
Nice! Thanks.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
  #107
Old 06-24-2021, 03:20 PM
K Roche's Avatar
K Roche K Roche is offline
Good to know thanks I have not installed yet but plan to do so next week
Absolutely love that red on inactive plugs.
Just got this in my e-mail from PT Expert on some of the new features
https://www.pro-tools-expert.com/hom...eid=3af5b4ba3b
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #108
Old 06-24-2021, 03:22 PM
LukeHoward LukeHoward is offline
IIRC Rosetta (translated) apps only run on the performance cores.
https://lukehoward.com/
  #109
Old 06-24-2021, 04:51 PM
glogulus2003 glogulus2003 is offline
Welp. My install didn't go so well. I've got an HDX2 system and after installing the hd driver and the latest 2021.6.0 my system isn't showing the cards and digitest shows no cards. That's just great.
Edit: Seems like an installation issue. For some reason:
sudo kextload /Library/Extensions/DigiDal.kext
Works and I can use the device. Uhh.. now how do I make it so I don't have to load it manually every time?
  #110
Old 06-24-2021, 05:07 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
What model of computer are you using? Is it an M1 Mac? If so, the HD Driver isn’t supported yet for M1 Macs, which prevents HDX and HD Native from being used.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility Spoil the Child macOS 19 04-05-2021 05:35 PM
Pro Tools First 2021.3 is out Netmania Pro Tools | Intro Discussion 2 04-02-2021 01:26 PM
