Old 08-24-2011, 01:28 PM
flysnailfly flysnailfly is offline
Default Need help with commercial use issue
Hi, I'm a youtuber!
http://www.youtube.com/flysnailfly
I make music for my youtube videos.
Youtube was warning me that I don't own the rights.
is that true? cause it'll be damn waste of money.
if so, can someone link me to where it says i'm able to
so I can sort this issue out?
Old 08-24-2011, 01:44 PM
rayg's Avatar
rayg rayg is offline
Default Re: Need help with commercial use issue
You need to post in the General Discussion..Check out the YouTube Community Guidelines...
Old 08-24-2011, 02:34 PM
HD2 HD2 is offline
If you "make" the music then surely you own the copyright no?
By "make" do you mean you actually write and create the music?
Old 08-24-2011, 04:23 PM
zedhed's Avatar
zedhed zedhed is offline
You may have issues if you are using sample libraries to create music. Each Library comes with it's own set of rules about using their samples to create music commercially. You need to check the conditions that come with any library you use. There are also copyright issues whether using samples or your own instruments to play cover songs for commercial use. You will of course need to determine from YouTube what they consider 'Commercial' to be. One may not need to be making money for them to categorize it as commercial use.
If you are writing & creating a totally original tune recording your own Instruments/Samples Voice then I can't see what the problem could be.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
[IMG] code is Off
Commercial Post in 5.1? EarHole Post - Surround - Video 19 11-10-2005 07:26 AM
OT: funny commercial Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-17-2004 01:35 PM
Commercial Release Record-n-Play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2002 01:41 PM
getting my signals as hot as commercial cds surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 08-22-2002 04:24 PM
Commercial Compression (again) Arno Peeters Tips & Tricks 16 06-17-2000 06:06 PM
