#7091
Re: Sweet Indeed
I like Waiting, but my downstairs neighbors don't like the bass. Too bad. As for Jim Morrison meets The Knuckle Song...don't know what to say. A melancholy rendering of that annoying little number is probably long overdue.
Rabbit |
#7092
Re: Hey Dave C, the Tard here...
Thanks, John....it was mastered using a UAD Multiband mastering Compressor by JT Treeby at JT Studios here in Memphis. As far as my initial mix, here’s what’s in it… Drums- programmed the drums in ReDrum/PT midi using my own best samples... Bass-$200 Ibanez with low E tuned to a D through a tweaked Amplitube setting I named 'Wicked', because it is...hehe Clean solo guitar stuff- Strat through GuitRig/tweaked clean setting with some verb and delay. My strat is my favorite clean sound guitar in most cases. Hard guit solo- My custom guitar through GuitRig/tweaked overdrive setting. String sounds(2), Sampletank II and Samplecell patches converted for use in Reason. I had also created a low cellos section for this which was cool by itself but cluttered up the overall mix, so it was out of there. High choir, violin plucks-STII Organs(2)- one is a Norman Cook organ with some slight delay, the other is a Korg percussive organ run slightly through a Screamer in Reason to give it an overdriven leslie sound. These 2 organs play off each other. 12 string- Samplecell patch converted for use in Reason. Mandolin stuff- real mandolin samples I recorded a few years ago, with which I create custom 'stuff' to import into other sessions like 'Gypsy'. These can be very effective. gypsy heart I'll be listening to the new songs here hopefully tonight...thanks for the comments. -Roy
rh music |
#7093
All,
Have been working with a younger band. Good ideas, bad planning, but trying to work through it. Here is a mix without vocals. Still trying to tailor those some. Not sure what to do on that one. This has some intonation issues, but mainly the way that they play SUPER LIGHT strings and their bends. Told them, but they liked it. I am happy with the sounds. Kinda tough to work with and I had to go and tweek some of the slower bass parts and replay it. NEVER CHANGE STRINGS THE DAY OF RECORDING!!!!! Setup was this: GRID MODE AND CLICK DEFINITELY! Made it easy to loop parts, and cut to all hell later. Kick - D6 - X73i - Apogee Subkick - Yamaha Subkick - 1272 - Apogee Snare Top - SM57 - X73i - Apogee - NEW PORK LITE SNARE TOO! MONEY! Snare Bottom - SM57 - 1272 - Apogee hat - Oktava 012 - Trident S20 - DIGI Ride -Oktava 012 - Trident S20 - DIGI Overhead Ride - APEX 435 - API - Distressor - Apogee (new way) Overhead Hat - APEX 435 - API - Distressor - Apogee Tom 1 - 421 - API - Apogee Floor - 421 - API - Apogee GUITARS - Fender Prosonic head and Boogie Single Rec - blended Bogner Cab with a 421 and SM57 taped together on the lower speaker. 57 - X73i - Apogee 421 - 1272 - Apogee Bass - Hamer - 1272 - 1176 - Apogee Vocals will show up eventually. I had fun cutting this. I added the ambient key in the beginning and the end. Also added the power chord part in the beginning (GRID MODE RULES!) and the first chop cut is gone now, but not in this mix. added some to the 4:20 cut to make it extend a full measure instead of the initial 4 times. Really dig it minus a few things here and there. Oh well, what can ya do but press on.. BODY BAGS - NO VOX Oh ya, Ran this mix back out to the API and shot it through the MIX BUSS. Really like what it does forthe overall punch. Enjoy Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
#7094
Hey Doc, I like this feel "Body Bags". I feel some emotion there. If you don't mind I would like to write vocal melody line and send it to you? I wrote a vocal melody to one of Roy Howell's pieces called Moonbean Seduction. Maybe he would share it with you.
Its just for the creativeness of it all. Nick |
#7095
This is fantastic stuff... good job and good tune nice ending.
#7096
If you want to write a melody send it... Once you hear the initial vocal take you may change your mind... haha! I was able to talk him into retaking the vocals and trying to at least push it and make the key. He agreed so that is a start. Just holding back, and honestly it is out of his range. He tries, but needs to figure it out. Going to try again this weekend and see what we get, otherwise I am done. Aotutine would not fix it either.
Body Bags - Vox - ROUGH! Vocals - RODE NTK - 1272 - Apogee Email a link to the ideas and I will check it out. The ambient stuff at the beginning I did. Actually played the guitar power chords and added 8 measures to build it some. Think it flowed better somewhat. Then I added the key part and used Atmosphere for that. The feedback at the end blended nice with the keys I think. Thank, I just hope the vocals can get better. VERY RAW here. I shot this mix back out and through the X73i's to warm it up some. Really liked it and left a lot of dynamics instead of the typical BRICK wave form. Later... Doc
#7098
Re: Doc
Dave,
No offense taken, just curious really. Re-mastering a 320kps MP3? Seems like a waste of time, but have fun. I put a new much tamer mix up that has vocals (if you call it that) above. He is going to retrack the vocals this weekend and belt out some stuff. Anyways, no worries man, have fun. Know this that I already ran the stuff through. This new mix goes out to the X73i's from the stereo 48/24 bounce, back into the Apogee. That also had a Lin Mb on it, rolled off 50 through the 73i's. yada yada From the 48/24 session I bounced that to 44/24. Then added the L2 and the PowR and turned the Dither off on the L2 and used the PowR to dither. No if I can get a good vocal take this may be a decent song... Doc
#7099
Re: Doc
No I know man not the greatest start-out quality to begin with. Just having fun wasting my time
#7100
A little heavier side of things....
We finally have a full line up and needed a couple songs for pimpin' on myspace.
Not really happy with the drums but for a couple days recording everything it will work. www.myspace.com/risetofight Roy... One of these songs didnt have vocals way back when and you wanted to hear some vocs. Im sure it's not your thing but here ya go |
Link to 'Latest Stuff' songs.... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-25-2005 07:46 PM |
Lets hear your latest stuff????? | toofly4asoundguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-25-2004 02:19 AM |
Let's hear your latest stuff... that totaly STINKS! | funkdefino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 08-25-2002 07:59 PM |
Let's hear your latest stuff....that doesn't suck | mxmasterskrach | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 37 | 08-19-2002 04:03 PM |
So what's the latest word on AMD stuff? | AirPolski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-30-2001 05:30 PM |
