Random freezes using Pro Tools 9 on new Macbook running Lion OS (blue screen editing)
I'm getting random freezes using Pro Tools 9 in a brand new 15' Mid 2012 Macbook Pro running Lion. Everything is updated. I have the latest version of Lion and Pro Tools 9. I have a MOTU interface, all updated as well. It's usually when I'm editing tracks. It just freezes and it doesnt even allow me to Force Quit. I have to manually restart the computer. Most the times I can still move the cursor but apart from that, nothing else works. I've also noticed that while I'm editing tracks (usually using the warp option on guitar tracks) the screen turns completely blue, white or green. It goes away when I click the mouse somewhere. After a while it just freezes. I have every thing up to date and I still can't figure out why this is happening. Anybody else getting this or know why this is happening?
Re: Random freezes using Pro Tools 9 on new Macbook running Lion OS (blue screen edit
Are you:
- Running PT 9.0.5? - Using your OS drive to record/edit files? - Is your OS drive an SSD? |
And have you done all of the Avid recommended optimizations for Pro Tools, especially including turning off spotlight indexing on your audio drive. If you are using your system drive and have spotlight on you may be doubly screwed. Yes Lion seems to make the system hang periodically much worse than Snow Leopard but so far in my experience this only happens when things are not setup properly.
Darryl |
Thanks a lot Darryl. I will check that out as soon as I get home. The hard drive is not an SSD. The PT projects are on my desktop and in my documents folder. Don't remember right now the exact version of Pro Tools but I know that when I installed it, it asked for an update and I did it. Will get back after I check the setup.
Hi there,
I am running also a MacBook pro 15 mid 2012 with Lion and protools 9. I do not have any freeze issues but I do have also the graphic issue: once in a while the edit window flashes blue or red or green and then everything return to normal. I work with an external 7200 hd FireWire. And experienced this with 9.05 and 9.06. Any ideas from avid people ? Thanks Best Simon |
If it is a retnia display - it is not a standard Lion software - it is a special build that allows for the different graphics resolution......
maybe the issue I don't know....Just saying.
Thxs no that's the non retina MacBook pro
Anyone? |
Sorry Anyone has an idea?
Thxs |
digi003 factory win7 64 bit freezes or blue screen | hkk009008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-07-2011 09:02 AM |
Random Screen Freezes | themidiroom | Pro Tools TDM Systems (Mac) | 2 | 05-21-2007 09:57 AM |
HELP! Screen Freezes (just screen) While Running 6.1.1 on XP Home | Brentsky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-27-2004 08:54 AM |
My screen freezes at random times, HELP! | jrpieslak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-22-2004 06:07 AM |
Help!! Constant SCREEN FREEZES and Out of the Blue SYSTEM REBOOTS ITSELF! | asher400 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-07-2003 10:15 AM |
