Old 06-09-2021, 10:14 AM
ArchStanton ArchStanton is offline
Default Setting RMS and Peak values
Hi guys,
I process a lot of audio for voice recording and have very specific specs to meet. Between -23dB and -18dB RMS and have -3dB peak values and a maximum -60dB noise floor.
Is there any built in plug-in (or even one I can buy) where I can enter these parameters and render it off?
At the minute, I'm just using a built in compressor/limiter but over long audio files (45+ minutes) occasionally the RMS will fall too low or there might be the odd spike that sends the peak over -3dB.
The audio is recorded elsewhere, by amateurs, not using Pro Tools so it all has to be sorted after the recording process.
Any help, much appreciated.
Thanks
Old 06-09-2021, 10:21 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Setting RMS and Peak values
Possibly Waves WLM Plus.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-09-2021, 10:26 AM
daeron80 daeron80 is offline
WLM Plus gives you a read out after playback. For offline conforming, iZotope RX is brilliant. But it goes by LUFS, not RMS. Who the devil is using RMS for longterm loudness measurements these days?! That's like telling a builder how long to make your house in cubits.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 06-09-2021, 12:17 PM
mbourque mbourque is offline
Maybe something like that? https://nugenaudio.com/lm-correct
Matthieu Bourque
PT Ultimate 2022.10 on macOS 12.6.1
Old 06-10-2021, 07:45 AM
elicious elicious is offline
Free...
Also, the included Gain Audio Suite plug-in can read a file and give you RMS and peak readings,
as well as the old Slate FG-X can do it in real time.
Best of luck…
ihatetyping
Setting Region Audio Peak Dinsane Pro Tools 10 0 07-24-2016 03:53 AM
Exact Plugin Setting Values strum macOS 3 05-22-2013 09:23 AM
Setting Values junkgear Eleven Rack 2 03-12-2012 08:05 AM
Off Topic: Masterlist and Peak Values Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-09-2001 03:14 PM
Adjusting Peak Values Paul B Goode Digidesign Hardware & Software 2 09-09-2001 03:09 PM
