Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 12-19-2014, 10:30 PM
OTPBAND OTPBAND is offline
Default Pro Tools "Not Responding" While Bouncing Audio to Disk
While trying to bounce audio from my session to disk, pro tools turns gray and Give a not responding error message and forces me to shut down pro tools. I've tried everything I can think of (BTW I'm new to pro tools). It wasn't doing this when I first installed pro tools. Does anybody have any suggestions on what to do? I'm kinda in a bind here...
Old 12-19-2014, 10:33 PM
Default Re: Pro Tools "Not Responding" While Bouncing Audio to Disk
BTW, in regards to my last post, after pro tools having to be forcefully shut down, two audio files show up where the bounce location was. They are not full of audio, they give an error message when opened.
Old 12-20-2014, 12:47 AM
nikhilmulay nikhilmulay is offline
It happens to me when I bounce to disk. Windows will go to the 'waiting ring' icon but the bounce is working fine in the background. It will ask to shut down only if I click on something. The bounce finishes just fine though.
I believe the cure might be to turn off aero. Look up windows optimisations on the avid website..
Old 12-20-2014, 03:33 AM
hjorte's Avatar
hjorte hjorte is offline
Try stopping (disable it) the below Windows service if you want the control back. Use at own risk. I've used it successfully for years with PT8, 9 and 10.
Desktop Window Manager Session Manager.
Two Files "L" and "R" when bouncing to disk? TruestPain Tips & Tricks 13 02-15-2016 08:51 AM
Bouncing Loops Leaves Audio "Hole" subwoof Pro Tools TDM Systems (Mac) 2 05-18-2012 09:35 AM
"Pro Tools not responding" error and a very "laggy" session! Help! drumbumd Pro Tools M-Powered (Win) 0 02-10-2012 05:37 PM
" Not responding" msg in win7 while starting pro tools v9 q8test Windows 2 07-31-2011 10:54 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
